[Qgis-developer] Null Value in QLineEdit
Enrico Fiore
enricofiore at libero.it
Sat Apr 4 03:01:06 PDT 2015
thanks for your answer.
I have done others tests, whit your suggestions
Il 04/04/2015 01:21, Nikhil Murarka ha scritto:
> try:
> if myDialog.findChild(QLineEdit,"cod_direzione").text() == "":
> myDialog.findChild(QLineEdit,"cod_direzione").setText("A")
> else:
> myDialog.findChild(QLineEdit,"cod_direzione").setText("NOT NULL")
> I think the text is not empty string intially because it work for me.
I tried with the else clause, and you are right it is like if the field
is not empty.
But it is strange because the form appear when I edit a new point, whit
all the form slots empty.
The layer is a Multipoint in a Postgresql database, the field is a
varchar(1) .
the field is recognised empty if I write this code:
if myDialog.findChild(QLineEdit,"des").text() == u"NULL":
myDialog.findChild(QLineEdit,"des").setText("A")
> Also where are you defining this statement ? -some callback function
> or __init__
I call the .py file inside the layer properties
> Can you post the complete function ?
from PyQt4.QtCore import *
from PyQt4.QtGui import *
from qgis.core import *
from qgis.gui import *
def formOpen(dialog, layerid, featureid):
myDialog = dialog
global myDialog
# Riferimento ai bottoni
buttonBox = dialog.findChild(QDialogButtonBox, "buttonBox")
# Disconnessione del segnale che QGIS ha automaticamente associato
alla zona dei pulsanti
buttonBox.accepted.disconnect(myDialog.accept)
# Connessione del nostro segnale
buttonBox.accepted.connect(validate)
buttonBox.rejected.connect(myDialog.reject)
def validate():
# cod_direzione default = A
if myDialog.findChild(QLineEdit,"des").text() == "":
else:
myDialog.findChild(QLineEdit,"des").setText("N")
