[Qgis-developer] committedGeometriesChanges issue
Enrico Fiore
enricofiore at libero.it
Wed Apr 8 06:32:04 PDT 2015
I am trying to perform a post-processing queries in a postgis layer. When a new point is insert all work fine, but if I move existing point the queries don't work. The event committedGeometriesChanges seems that doesn't work.
Is it because is not open the form dialog to perform this action?
I found this thread
http://osgeo-org.1560.x6.nabble.com/Post-processing-queries-on-postgis-layers-after-insert-delete-update-td5193956.html
where is written that it is a bug and that it is fixed in 65378e6
I tried both with QGIS 2.8.1 and QGIS 2.9.0.40.
Is it a mistake or the bug is not fixed? Is it necessary open a ticket?
The code that I use is
def formOpen(dialog, layerid, featureid):
layerid.commitedGeometriesChanges.connect(confirmChanged)
def confirmChanged(layerid, changedGeometries):
... update attribute with queries ....
Regards
Enrico Fiore
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150408/7201a4b5/attachment.html>
