[Qgis-developer] Error compiling QGIS v2.8.1 with Globe Plugin
samuelmesa at gmail.com samuelmesa at gmail.com
Wed Apr 8 09:04:12 PDT 2015
 I have achieved to install QGIS with Globe plugin with an older version of
osgEarth [1], specifically version 2.1.1 (2011). This version contains all
headers required to compile QGIS globe plugin. However, an error occurs when
starting QGIS and closes with the following message:
$ qgis
Warning: QGraphicsScene::addItem: item has already been added to this scene
Violación de segmento (`core' generado)
  To correct the error I remove the Globe plugin of
/usr/lib/qgis/plugins/libglobeplugin.so. However, I can not accomplish install
the Globe plugin in QGIS.
[1] https://gist.github.com/samtux/5efb2512d18ec682c64c
2015-04-08 7:58 GMT-05:00 samuelmesa at gmail.com <samuelmesa at gmail.com>:
> Hello list. I support in generating GIS AUR packages in Arch Linux
> repositories, including osgEarth package [1]. However in the latest
> version of QGIS v2.8.1, I was unable successfully compile osgEarth to
> support the Globe plugin, because it requires some headers that do not
> exist.
> QGIS with osgEarth version 2.5 not find osgEarth/FindNode:
> /home/samtux/Manjaro/aur/qgis/src/qgis/src/plugins/globe/osgEarthUtil/Controls.cpp:21:29:
> error fatal: osgEarth/FindNode: No existe el fichero o el directorio
>  #include <osgEarth/FindNode>
> compilación terminada.
> src/plugins/globe/CMakeFiles/globeplugin.dir/build.make:170: fallo en las
> instrucciones para el objetivo
> 'src/plugins/globe/CMakeFiles/globeplugin.dir/osgEarthUtil/Controls.cpp.o'
> make[2]: ***
> [src/plugins/globe/CMakeFiles/globeplugin.dir/osgEarthUtil/Controls.cpp.o]
> Error 1
> CMakeFiles/Makefile2:2570: fallo en las instrucciones para el objetivo
> 'src/plugins/globe/CMakeFiles/globeplugin.dir/all'
> make[1]: *** [src/plugins/globe/CMakeFiles/globeplugin.dir/all] Error 2
> make[1]: *** Se espera a que terminen otras tareas....
> QGIS with osgEarth version 2.6 not find osgEarthUtil/SkyNode:
> /home/samtux/Manjaro/aur/qgis/src/qgis/src/plugins/globe/globe_plugin.cpp:60:32:
> error fatal: osgEarthUtil/SkyNode: No existe el fichero o el directorio
>  #include <osgEarthUtil/SkyNode>
> src/plugins/globe/CMakeFiles/globeplugin.dir/build.make:78: fallo en las
> 'src/plugins/globe/CMakeFiles/globeplugin.dir/globe_plugin.cpp.o'
> make[2]: ***
> [src/plugins/globe/CMakeFiles/globeplugin.dir/globe_plugin.cpp.o] Error 1
> How could correct this error?, someone has the same problems with osgEarth
> in other Linux distributions?
> regards,
> Samuel Mesa.
> [1] https://aur.archlinux.org/packages/osgearth
   / v \
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150408/94bf2741/attachment-0001.html>
