[Qgis-developer] Error compiling QGIS v2.8.1 with Globe Plugin
samuelmesa at gmail.com samuelmesa at gmail.com
Thu Apr 9 13:23:11 PDT 2015
Matthias thanks for your answer. The truth I'm not very expert programming,
but try to compile the code Globe plugin that you provide. The Globe plugin is
very interesting and useful, however wait until QGIS updates that supports the
latest version of osgEarth.
regards
Samuel Mesa.
2015-04-08 16:06 GMT-05:00 Matthias Kuhn <matthias at opengis.ch>:
>  Hi,
> a year ago I updated globe to be compatible with newer OSGEarth versions
> (up to 2.5 IIRC) but never got around to merge the code back.
> In case somebody wants to finish this work, the code is here:
> https://github.com/m-kuhn/QGIS/tree/globe-featurequery/
> Be prepared however that quite a bit of code was changed in QGIS core as
> well because some functionality to make globe more configurable (expose
> vector layers as such, extrude features, height exaggeration of the DEM and
> at some point some python scripting possibilities...) was added what
> required to add the possibility to add additional tabs to the vector layer
> properties dialog from plugins.
> You have been warned that it's not just a simple patch.
> Best,
> Matthias
> On 04/08/2015 06:04 PM, samuelmesa at gmail.com wrote:
>    I have achieved to install QGIS with Globe plugin with an older version
> of osgEarth [1], specifically version 2.1.1 (2011). This version contains all
> headers required to compile QGIS globe plugin. However, an error occurs
> when starting QGIS and closes with the following message:
> $ qgis
> Warning: QGraphicsScene::addItem: item has already been added to this scene
> Violación de segmento (`core' generado)
>      To correct the error I remove the Globe plugin of
> /usr/lib/qgis/plugins/libglobeplugin.so. However, I can not accomplish install
> the Globe plugin in QGIS.
> [1] https://gist.github.com/samtux/5efb2512d18ec682c64c
> 2015-04-08 7:58 GMT-05:00 samuelmesa at gmail.com <samuelmesa at gmail.com>:
>>  Hello list. I support in generating GIS AUR packages in Arch Linux
>> repositories, including osgEarth package [1]. However in the latest
>> version of QGIS v2.8.1, I was unable successfully compile osgEarth to
>> support the Globe plugin, because it requires some headers that do not
>> exist.
>> QGIS with osgEarth version 2.5 not find osgEarth/FindNode:
>> /home/samtux/Manjaro/aur/qgis/src/qgis/src/plugins/globe/osgEarthUtil/Controls.cpp:21:29:
>> error fatal: osgEarth/FindNode: No existe el fichero o el directorio
>>  #include <osgEarth/FindNode>
>> compilación terminada.
>> src/plugins/globe/CMakeFiles/globeplugin.dir/build.make:170: fallo en las
>> instrucciones para el objetivo
>> 'src/plugins/globe/CMakeFiles/globeplugin.dir/osgEarthUtil/Controls.cpp.o'
>> make[2]: ***
>> [src/plugins/globe/CMakeFiles/globeplugin.dir/osgEarthUtil/Controls.cpp.o]
>> Error 1
>> CMakeFiles/Makefile2:2570: fallo en las instrucciones para el objetivo
>> 'src/plugins/globe/CMakeFiles/globeplugin.dir/all'
>> make[1]: *** [src/plugins/globe/CMakeFiles/globeplugin.dir/all] Error 2
>> make[1]: *** Se espera a que terminen otras tareas....
>> QGIS with osgEarth version 2.6 not find osgEarthUtil/SkyNode:
>> /home/samtux/Manjaro/aur/qgis/src/qgis/src/plugins/globe/globe_plugin.cpp:60:32:
>> error fatal: osgEarthUtil/SkyNode: No existe el fichero o el directorio
>>  #include <osgEarthUtil/SkyNode>
>> src/plugins/globe/CMakeFiles/globeplugin.dir/build.make:78: fallo en las
>> 'src/plugins/globe/CMakeFiles/globeplugin.dir/globe_plugin.cpp.o'
>> make[2]: ***
>> [src/plugins/globe/CMakeFiles/globeplugin.dir/globe_plugin.cpp.o] Error 1
>> How could correct this error?, someone has the same problems with
>> osgEarth in other Linux distributions?
>> regards,
>>  Samuel Mesa.
>>  [1] https://aur.archlinux.org/packages/osgearth
>    / v \
> Qgis-developer mailing listQgis-developer at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-developer
   / v \
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150409/27e070cc/attachment.html>
