[Qgis-developer] How to load a QLR file with pyQGIS ?
Gary Sherman
gsherman at geoapt.com
Thu Apr 16 07:53:24 PDT 2015
On 4/15/15 10:55 PM, Nathan Woodrow wrote:
> Hey,
> QLR files are not style files they can't be loaded like that.
OH :) My brain read QML...
> Unfortunately the API for loading a QLR is broken in 2.8.1 but will be
> fixed in 2.8.2, however the logic isn't very complex and you can
> translate it to Python from C++. The source is here
> https://github.com/qgis/QGIS/blob/master/src/core/qgslayerdefinition.cpp#L36.
> If you don't need to support loading groups from the QLR you can use this:
> QList<QgsMapLayer*> layers = QgsMapLayer::fromLayerDefinition( doc );
> QgsMapLayerRegistry::instance()->addMapLayers( layers, True);
> - Nathan
> On Thu, 16 Apr 2015 at 16:51 Geo DrinX <geodrinx at gmail.com
> <mailto:geodrinx at gmail.com>> wrote:
> Very strange :(
> I inserted also the triggerRepaint() but nothing changes.
> This is my sourcecode:
> https://github.com/geodrinx/smartroadsense/blob/master/smartroadsense.py
> If I drag and drop in QGIS my "srs_data.qlr" file, it works.
> Instead, from python code, the style is not applied.
> Could be because my data file is a CSV?
> 2015-04-15 18:39 GMT+02:00 Gary Sherman <gsherman at geoapt.com
> <mailto:gsherman at geoapt.com>>:
> On 4/15/15 2:24 AM, Geo DrinX wrote:
> Hello,
> there is a way to load a QLR file with pyQGIS ?
> I tried using vlayer.loadNamedStyle(__qlrFileName)
> but it seems
> not to work.
> What is the correct way ?
> That is the correct way. Have you done the following after
> applying the style?:
> vlayer.triggerRepaint()
> You can test the result of applying the style using:
> result = vlayer.loadNamedStyle(__qlrFileName)
> If result if False, the style was not loaded/applied.
> -gary
> Thank you
> Roberto
> _________________________________________________
> Qgis-developer mailing list
> <mailto:Qgis-developer at lists.osgeo.org>
> http://lists.osgeo.org/__mailman/listinfo/qgis-__developer
> <http://lists.osgeo.org/mailman/listinfo/qgis-developer>
> Gary Sherman
> Founder, QGIS Project
> Consulting: geoapt.com <http://geoapt.com>
> Publishing: locatepress.com <http://locatepress.com>
> We work virtually anywhere
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
Gary Sherman
