[Qgis-developer] Force canvas to predefined scales : help needed to improve a script
kimaidou
kimaidou at gmail.com
Fri Apr 17 03:27:19 PDT 2015
Hi Hugo,
Thanks for the anwser. I used some "print scale" and "print targetScale" in
my script to check the behavious, and I did not have any "infinite loop" or
strange behaviour with it. It seems the related QGIS code is armed against
this risks.
This python script was only a prototype, and I will surely have a look at
the cpp classes and propose a PR to add this option in QGIS core.
Michaël
2015-04-17 11:26 GMT+02:00 Hugo Mercier <hugo.mercier at oslandia.com>:
> Hi,
> Le 17/04/2015 10:46, kimaidou a écrit :
> > Hi QGIS !
> > I would like to be able in QGIS to force the canvas scales to some
> > predefined ones. Since we now have project scales (and QGIS pre-defined
> > scales) in the scale selector, we could use them, and add a simple
> > checkbox near the combobox "Stick to predefined scales".
> > The aim is to force the canvas to render only at these scales. For
> > example, if I use the rectangle zoom tool, and I should go toe 1/56003,
> > I would instead land on 1/50000 , the closest pre-defined scale.
> That would be nice to have it in the core. I already had to do something
> similar with a plugin.
> > I made a little python script as a proof of concept to illustrate it :
> > http://paste.debian.net/167247/
> > In this script, I hard coded the scales, but oviously we should get them
> > from the project properties.
> > I have a question regarding my script. Since I use the
> > QgsMapCanvas::scaleChanged signal, I assume the rendering is done twice
> > ? Once the "normal" way, and once again after I use the
> > QgsMapCanvas::zoomScale method after calculating the new target scale.
> > Any idea for improving it ? I assume I would have to disconnect one (not
> > found yet) signal/slot, then set the scale and reconnect this
> > signal/slot afterwards ?
> QObject::blockSignals might be of help here. But in this case, you don't
> want to block all signals, only yours.
> I guess your solution would work.
> You can also use a flag in your callback, something like :
> def setScale( self, scale ):
> if self.reentrant:
> return
> targetScale = min(
> self.predefinedScales,
> key=lambda x:abs(x-scale)
> self.reentrant = True
> self.mc.zoomScale( targetScale )
> self.reentrant = False
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150417/75503c61/attachment-0001.html>
