[Qgis-developer] Force canvas to predefined scales : help needed to improve a script
Nathan Woodrow
madmanwoo at gmail.com
Fri Apr 17 05:40:42 PDT 2015
And here is a different way using just functions:
(https://gist.github.com/mdouchin/72a09b629a5557c1dc1c#comment-1435388)
def forcedScale(*scales):
replayed = False
def setScale(scale ):
iface.mapCanvas().scaleChanged.disconnect(setScale)
print "initial scale: %s" % scale
targetScale = min(
scales,
key=lambda x:abs(x-scale)
if targetScale == scale:
return
print "zoom to %s" % targetScale
iface.mapCanvas().zoomScale( targetScale )
iface.mapCanvas().scaleChanged.connect(setScale)
# pre-defined scales
predefinedScales = [
5000,
10000,
25000,
50000,
100000,
250000,
500000
# avoid loop
if not scales:
scales = predefinedScales
On Fri, 17 Apr 2015 at 22:34 kimaidou <kimaidou at gmail.com> wrote:
> More pythonesque Nathan, thanks !
> 2015-04-17 14:32 GMT+02:00 Nathan Woodrow <madmanwoo at gmail.com>:
>> def __init__( self, *predefinedScales ):
>> and you can do this
>> forcedScale(25000, 50000, 100000)
>> On Fri, 17 Apr 2015 at 22:30 kimaidou <kimaidou at gmail.com> wrote:
>>> Hi all,
>>> Improve version here:
>>> with:
>>> * "replayed" variable to avoid probable infinite loop, thanks to Hugo's
>>> proposal
>>> * you can now initialize the method with a python list of scales you
>>> want to force canvas to:
>>> fs = fs = forcedScale( [25000, 50000, 100000 ] )
>>> Cheers,
>>> Michaël
>>> 2015-04-17 12:27 GMT+02:00 kimaidou <kimaidou at gmail.com>:
>>>> Hi Hugo,
>>>> Thanks for the anwser. I used some "print scale" and "print
>>>> targetScale" in my script to check the behavious, and I did not have any
>>>> "infinite loop" or strange behaviour with it. It seems the related QGIS
>>>> code is armed against this risks.
>>>> This python script was only a prototype, and I will surely have a look
>>>> at the cpp classes and propose a PR to add this option in QGIS core.
>>>> Michaël
>>>> 2015-04-17 11:26 GMT+02:00 Hugo Mercier <hugo.mercier at oslandia.com>:
>>>>> Hi,
>>>>> Le 17/04/2015 10:46, kimaidou a écrit :
>>>>> > Hi QGIS !
>>>>> > I would like to be able in QGIS to force the canvas scales to some
>>>>> > predefined ones. Since we now have project scales (and QGIS
>>>>> pre-defined
>>>>> > scales) in the scale selector, we could use them, and add a simple
>>>>> > checkbox near the combobox "Stick to predefined scales".
>>>>> > The aim is to force the canvas to render only at these scales. For
>>>>> > example, if I use the rectangle zoom tool, and I should go toe
>>>>> 1/56003,
>>>>> > I would instead land on 1/50000 , the closest pre-defined scale.
>>>>> That would be nice to have it in the core. I already had to do
>>>>> something
>>>>> similar with a plugin.
>>>>> > I made a little python script as a proof of concept to illustrate it
>>>>> > http://paste.debian.net/167247/
>>>>> > In this script, I hard coded the scales, but oviously we should get
>>>>> them
>>>>> > from the project properties.
>>>>> > I have a question regarding my script. Since I use the
>>>>> > QgsMapCanvas::scaleChanged signal, I assume the rendering is done
>>>>> twice
>>>>> > ? Once the "normal" way, and once again after I use the
>>>>> > QgsMapCanvas::zoomScale method after calculating the new target
>>>>> scale.
>>>>> > Any idea for improving it ? I assume I would have to disconnect one
>>>>> (not
>>>>> > found yet) signal/slot, then set the scale and reconnect this
>>>>> > signal/slot afterwards ?
>>>>> QObject::blockSignals might be of help here. But in this case, you
>>>>> don't
>>>>> want to block all signals, only yours.
>>>>> I guess your solution would work.
>>>>> You can also use a flag in your callback, something like :
>>>>> def setScale( self, scale ):
>>>>> if self.reentrant:
>>>>> return
>>>>> targetScale = min(
>>>>> self.predefinedScales,
>>>>> self.reentrant = True
>>>>> self.mc.zoomScale( targetScale )
>>>>> self.reentrant = False
>>>>> _______________________________________________
>>>>> Qgis-developer mailing list
>>>>> Qgis-developer at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150417/c273c4a1/attachment-0001.html>
