[Qgis-developer] Error in running some SAGA modules in OSGeo4W 64 bit
Giovanni Manghi
giovanni.manghi at gmail.com
Sun Apr 19 03:57:23 PDT 2015
> Hi all.
> Some saga modules under Processing (e.g. fill sinks) fail with:
> ERROR 1: Can't load requested DLL:
> C:\PROGRA~1\QGISWI~1\apps\saga\dll\gdal_MrSID.dll
> 127: The specified procedure could not be found.
> I suspect a problem in the installer: anyone confirms?
the error/message is non blocking, the module just seems to be slow
for fair large input dems. The message do not shows when using saga
natively and under qgis disappear if that dll is removed, so it should
be something in the osgeo4w environment (also 32bit).
