[Qgis-developer] Automate snapping after insert of a new feature
francescoboccacci at libero.it francescoboccacci at libero.it
Wed Apr 22 02:01:08 PDT 2015
Hi all,
i have a question for you. I'd like to have a new function in my plugin that makes an autime snapping if a start point or end point of a new feature inserted is closed to a vertex or segment base on a values setted ina configuration file.
>From plugin console:
l = iface.activeLayer()  --activeLayer
f = l.selectedFeatures()[0] -- new fetaure inserted
start = f.geometry().asPolyline()[0] -- get the start point (the point that i would like to snap to a segment)
result = l.snapWithContext(start,10,QgsSnapper.SnapToVertexAndSegment) -- i use
result
(0, {0.0: [<qgis._core.QgsSnappingResult object at 0x0000000018B9C400>], 0.09699529788394015: [<qgis._core.QgsSnappingResult object at 0x0000000018B9C620>]})
I notice that the key 0.09699529788394015 is the effective distance between my start point and the segment.
My question is:
How can i modify the feature geometry to snap to the segment according to result?
Thanks
Francesco
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150422/b59d65a7/attachment-0001.html>
