[Qgis-developer] KMZ not parsed into columns?
Even Rouault
even.rouault at spatialys.com
Wed Apr 22 05:11:40 PDT 2015
Le mercredi 22 avril 2015 13:43:59, Paolo Cavallini a écrit :
> Hi all.
> Opening a KMZ results in a layer with several fields, but most info is
> stored in a "description" field, where all the xml is written, without
> parsing it into columns. Is this a GDAL limitation? Any better solution?
Care to share a snippet of the KML file ? I guess it is rather HTML inside the
<description> element. There's a way of putting structured data with proper
fields declaration in KML, but HTML arrays are not uncommon.
> Thanks.
http://www.spatialys.com
