[Qgis-developer] qgis-web-client: module wsgi
Bernhard Ströbl bernhard.stroebl at jena.de
Thu Apr 23 22:44:47 PDT 2015
Hi Enzo,
I did not realize you solved it in the meantime :-)
regards
Bernhard
Am 24.04.2015 07:42, schrieb Bernhard Ströbl:
> Hi Enzo,
> check Apache's error log (located e.g. in /var/log/apache2) and see if
> there is some more information.
> Bernhard
> Am 23.04.2015 19:33, schrieb Enzo Cocca:
>> Hi Bernard,
>> I have followed
>> If I put the wsgi folder in /usr/lib/cgi-bin/ and set apache config like
>>    WSGIDaemonProcess gis processes=5 threads=15 display-name=%{GROUP}
>>    WSGIScriptAlias /wsgi/ /usr/lib/cgi-bin/wsgi/
>>    WSGIScriptAliasMatch ^/wsgi/([^/]+) /usr/lib/cgi-bin/wsgi/$1.wsgi
>> I have internal error 500. You  I'm not understand  again
>> sorry
>> E
>> 2015-04-23 9:42 GMT+04:00 Bernhard Ströbl <bernhard.stroebl at jena.de
>> <mailto:bernhard.stroebl at jena.de>>:
>>     Hi Enzo,
>>     do not put it into html (see section 6 of the QWC documentation)
>>     maybe in that location it is not run as a script but accessed by the
>>     browser as any other html file (remember: I am no expert on this).
>>     Basically you should not see the file at all in the browser, if an
>>     error occurs it should be in Apache's error log.
>>     Be sure ther is no space as the first character of the first line
>>     (as was suggested before).
>>     Bernhard
>>     Am 22.04.2015 22:15, schrieb Enzo Cocca:
>>         I continue to have the problem with mod_wsgi module. I not
>>         understand....  I have set the  apache config like suggest
>>         bernhard and
>>         I have put my wsgi folder in /var/www/html but I continue to
>>         have the error:
>>         illegal charcther #! /usr/bin/python
>>         I have reinstalled libapache2-mod-wsgi, but nothing
>>         I use ubuntu server 14.04 apache 2.4 python 2.7
>>         Thanks at all for help
>>         E
>>         2015-04-22 16:32 GMT+04:00 Bernhard Ströbl
>>         <bernhard.stroebl at jena.de <mailto:bernhard.stroebl at jena.de>
>>         <mailto:bernhard.stroebl at jena.de>>>:
>>              Hi Enzo,
>>              as I wrote in a previous post: Make sure the user running
>>         the apache
>>              process has access to the wsgi directory. Try putting the
>>         wsgi in
>>              /home/somthing e.g. in /var/www/wsgi
>>              Bernhard
>>              Am 22.04.2015 14:07, schrieb Enzo Cocca:
>>                  Hi all,
>>                  I looked for a solution but without results.
>>                  After set the default file in apache like that:
>>                  <VirtualHost *:80>
>>                      ServerAdmin webmaster at localhost
>>                      ServerName <localhost>
>>                      DocumentRoot /var/www/html/wms/site
>>                      <Directory />
>>                        Options FollowSymLinks
>>                        AllowOverride None
>>                      </Directory>
>>                      <Directory /var/www/html/wms/site/>
>>                        DirectoryIndex index.php index.html
>>                        Options Indexes FollowSymLinks MultiViews
>>                        AllowOverride None
>>                        Order allow,deny
>>                        allow from all
>>                        Require all granted
>>                      </Directory>
>>                      ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
>>                      <Directory "/usr/lib/cgi-bin/">
>>                        AllowOverride None
>>                        Options +ExecCGI -MultiViews -SymLinksIfOwnerMatch
>>                        Order allow,deny
>>                        Allow from all
>>                        Require all granted
>>                        SetEnv QGIS_LOG_FILE /tmp/qgislog.txt
>>                      </Directory>
>>                      RewriteEngine On
>>                      RewriteRule ^/cgi-bin/.*$ - [F]
>>                      RewriteRule ^/wms/(.+)$
>>         /cgi-bin/qgis_mapserv.fcgi?map=/var/www/html/wms/projects/$1.qgs
>>                  [QSA,PT]
>>                      RewriteRule ^/maps/?$ / [PT]
>>                      RewriteRule ^/maps/([^\.]+)$ /qgiswebclient.html
>> [PT]
>>                      RewriteRule ^/maps/(.*) /$1 [PT]
>>                      #mod_wsgi
>>                      #LoadModule wsgi_module
>>         /usr/lib/apache2/modules/mod_wsgi.so
>>                      WSGIScriptAlias /wsgi/ /home/www/wsgi/
>>         /home/www/wsgi/$1.wsgi
>>                      <Directory "/home/www/wsgi/">
>>                            Order allow,deny
>>                            Allow from all
>>                      </Directory>
>>                      ErrorLog ${APACHE_LOG_DIR}/qgis-web-client-error.log
>>                      CustomLog
>>         ${APACHE_LOG_DIR}/qgis-web-client-access.log combined
>>                  </VirtualHost>
>>                  and the GlobaOptions.js like that;
>>                  //URL for custom search scriptsnull; //
>>                  var searchBoxQueryURL =  "/wsgi/search.wsgi?query="; //
>>         null:
>>                  var searchBoxGetGeomURL =
>>         "/wsgi/getSearchGeom.wsgi";//null; //
>>                  The status is:
>>                  NetworkError: 404 Not Found -
>> http://localhost/wsgi/search.wsgi?query=&searchtables=&query=qqq&cb=stcCallback1001
>>                  So it not found the path of wsgi, but in default config
>>         I have
>>                  give the
>>                  alias
>>                  any idea?
>>                  E
>>              __________ Information from ESET Mail Security, version of
>>         virus
>>              signature database 11515 (20150422) __________
>>              The message was checked by ESET Mail Security.
>>         http://www.eset.com
>>              _______________________________________________
>>              Qgis-developer mailing list
>>         Qgis-developer at lists.osgeo.org
>>         <mailto:Qgis-developer at lists.osgeo.org>
>>         <mailto:Qgis-developer at lists.osgeo.org>>
>>         http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>     __________ Information from ESET Mail Security, version of virus
>>     signature database 11519 (20150423) __________
>>     http://www.eset.com
>> Enzo Cocca PhD
>> in "Science and Technology for Archaeology and Cultural Heritage"
>> mail: enzo.ccc at gmail.com <mailto:enzo.ccc at gmail.com>
>> cell: +393495087014
> signature database 11525 (20150424) __________
> http://www.eset.com
__________ Information from ESET Mail Security, version of virus signature database 11525 (20150424) __________
http://www.eset.com
