[Qgis-developer] [Qgis-user] processing 'Import Vector into PostGIS database (available connections)'
DelazJ delazj at gmail.com
Wed Apr 29 09:48:48 PDT 2015
Hi Larissa,
I think there is a problem with most of the Processing tools that deal with
PostGIS table. They need you to check **save the password** option when
setting your PostGIS connection (menu Layer > Add PostGIS table) before
they work. And this is an issue as it oblige to have the password readable
in any project you create. Should I open a ticket for this (if there isn't
already one?)
Once you have saved your password, you get authentication and can proceed
unless you encounter an issue with geometry generation (as I did). But I
may have done something wrong. :(
Hope that helps ...
DelazJ
2015-04-29 16:47 GMT+02:00 Richard McDonnell <richard.mcdonnell at opw.ie>:
> There is an addon for QGIS called split, which will easily export vector
> data to a PostGIS database.
> You mention having issues with authentication, just make sure the user
> (database) has the correct access.
> You can also create a new user in PgAdmin3, giving full access.
> I hope this is of help.
> Regards,
> Richard.
> On 29/04/2015 10:44, Larissa Junek wrote:
> > Hello,
> > is there someone with experience in using the processing GDAL 'Import
> > Vector into PostGIS database (available connections)' algorithm?
> > I have problems with the authentication to the PostGIS database and
> > look for a workflow which can be inserted into the user manual then.
> > Kind regards,
> > Larissa
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
> OPW - Looking to the future - Caring for the past
> Email Disclaimer: http://www.opw.ie/en/disclaimer/
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150429/043605e6/attachment-0001.html>
