[Qgis-developer] Which plugin versions should be in the repo?
Alessandro Pasotti
apasotti at gmail.com
Wed Apr 29 23:31:17 PDT 2015
2015-04-29 21:29 GMT+02:00 Tom Chadwin <tom.chadwin at nnpa.org.uk>:
> Hello all
> I'm in the early stages of plugin development, and am adding alpha
> experimental versions to the QGIS repo quite frequently. As this is a new
> plugin, there is little third-party testing.
> I posted an experimental version, and then quickly discovered a
> fundamental error. I fixed it, and uploaded a new version.
> I deleted the version with the major bug. Is that correct? Or should I
> leave all versions up there even if faulty? All versions are on GitHub.
> Thanks
> Tom
Generally speaking it's up to you, I would suggest to delete experimental
versions after a while unless they target different QGIS minimum versions.
Leaving a faulty version in the repo is not useful for anybody, deletion is
the way to go.
Alessandro Pasotti
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150430/b9bd4588/attachment.html>
