[Qgis-developer] QGIS 2.10.1 Pisa - Read CSV file problem
Neumann, Andreas a.neumann at carto.net
Wed Aug 5 22:56:24 PDT 2015
In my opinion it is quite "special" to name columns with integer
numbers. Not what the average GIS user would do. In my own 2-decade GIS
career I never had such an issue.
I am not against fixing this issue, but I don't think it is a serious
issue. We have many more important issues in QGIS.
Andreas
On 2015-08-06 07:31, Zoltan Szecsei wrote:
> Hi Chris,
> Thanks for the opinion.
> Do I log this as a bug?
> Whilst I am quite happy to write a bash script to parse and alter my 500 CSV files, I do feel that this is likely a more serious issue, as it will affect, I assume a lot of, users that load CSV files to join them to their spatial data.
> Maybe the silence on this is because it either goes unnoticed, or there are many people just doing a work-around.
> Let me know.
> Thanks & regards,
> Zoltan
> On 2015/⁠08/⁠05 02:55, Chris Crook wrote: Hi Zoltan
> I think this could be classed as an error! The source code rejects field names that look like positive numbers (some digits optionally followed by a period and some more digits).
> I can't recall a reason why it should do this. It could be reasonable to require field names to be compatible to database attribute names, but I can't see any need for that within QGIS itself. This can go on a 'to-⁠do' list to fix...
> Cheers
> Chris
> -⁠-⁠-⁠-⁠-⁠Original Message-⁠-⁠-⁠-⁠-⁠
> From: Zoltan Szecsei [mailto:zoltans at geograph.co.za]
> Sent: Tuesday, 4 August 2015 10:27 p.m.
> To: Qgis-developer at lists.osgeo.org
> Subject: [Qgis-⁠developer] QGIS 2.10.1 Pisa -⁠ Read CSV file problem
> Hi,
> Using the above version on Win 7 64 bit, I read a CSV file (as attributes only)
> stipulating that "first record has field names"
> Record 1 is as follows:
> "SALnum","SALnam","1","2","3","4","5","6","7","8","9","10+"
> When I open the attribute table, I see that fields 1 & 2 have names SALnum
> and SALnam, but the rest are called 'Field_3', 'Field_4' and so on.
> When I edit record 1 of this CSV file to look like:
> "SALnum","SALnam","1p","2p","3p","4p","5p","6p","7p","8p","9p","10+p"
> The I get the correct field names (albeit 1p instead of just "1")
> Is this an error, or is there some reason further down the line, that attribute
> tables cannot have 'numeric' field names?
> Thanks and regards,
> Zoltan
> Zoltan Szecsei PrGISc [PGP0031]
> Geograph (Pty) Ltd.
> GIS and Photogrammetric Services
> P.O. Box 7, Muizenberg 7950, South Africa.
> Mobile: +27-⁠83-⁠6004028
> Fax: +27-⁠86-⁠6115323 www.geograph.co.za [1]
> This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
 Geograph (Pty) Ltd.
 Qgis-⁠developer mailing list
http://lists.osgeo.org/mailman/listinfo/qgis-developer [2]
Links:
[1] http://www.geograph.co.za
[2] http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150806/4933805c/attachment-0001.html>
