[Qgis-developer] Installation problems in QGIS 2.8.3 on Windows 7 - 64 bit
Luca Manganelli luca76 at gmail.com
Wed Aug 5 23:55:29 PDT 2015
On Wed, Aug 5, 2015 at 7:43 PM, Andre Joost <andre+joost at nurfuerspam.de> wrote:
> There should be a postinstall.log file in the \qgis folder. The installation
> must have been broken before the bat and desktop icon creation.
The log reports many "file not found" errors:
C:\Programmi\qgis\postinstall.log
OSGEO4W_ROOT=
OSGEO4W_STARTMENU=C:\ProgramData\Microsoft\Windows\Start Menu\Programs\QGIS Wien
OSGEO4W_ROOT_MSYS=\=/
C:\Programmi\qgis
C:\Programmi\qgis>"\bin\make-bat-for-py.bat"
Impossibile trovare il percorso specificato.
C:\Programmi\qgis>set ICON=\apps\grass\grass-6.4.3\etc\gui\icons\grass_osgeo.ico
ICON_CMD=\apps\grass\grass-6.4.3\etc\gui\icons\grass_cmd.ico
C:\Programmi\qgis>set BATCH=\bin\grass64.bat
C:\Programmi\qgis>textreplace -std -t ""\bin\grass64.bat
"textreplace" non Š riconosciuto come comando interno o esterno,
 un programma eseguibile o un file batch.
C:\Programmi\qgis>textreplace -std -t ""\apps\grass\grass-6.4.3\etc\fontcap
C:\Programmi\qgis>del ""\bin\grass64.bat.tmpl
Impossibile trovare il file specificato.
C:\Programmi\qgis>del ""\bin\grass64.tmpl
C:\Programmi\qgis>if not 1 == 0 mkdir
"C:\ProgramData\Microsoft\Windows\Start Menu\Programs\QGIS Wien"
Sottodirectory o file C:\ProgramData\Microsoft\Windows\Start
Menu\Programs\QGIS Wien gi… esistente.
C:\Programmi\qgis>if not 1 == 0 nircmd shortcut "\bin\nircmd.exe"
"C:\ProgramData\Microsoft\Windows\Start Menu\Programs\QGIS Wien\GRASS
GIS 6.4.3" "GRASS GIS 6.4.3 GUI" "exec hide """\bin\grass64.bat" -wx"
"\apps\grass\grass-6.4.3\etc\gui\icons\grass_osgeo.ico"
"nircmd" non Š riconosciuto come comando interno o esterno,
C:\Programmi\qgis>if not 1 == 0 nircmd shortcut "\bin\grass64.bat"
GIS 6.4.3" "GRASS GIS 6.4.3 Command Line" "-text"
"~$folder.desktop$" "GRASS GIS 6.4.3" "exec hide """\bin\grass64.bat"
-wx" "\apps\grass\grass-6.4.3\etc\gui\icons\grass_osgeo.ico"
C:\Programmi\qgis>for %f in ("C:\Users\ADMINL~1\AppData\Local\Temp")
do call set TEMPDRIVE=%~df
C:\Programmi\qgis>call set TEMPDRIVE=C:
C:\Programmi\qgis>cd C:\Users\ADMINL~1\AppData\Local\Temp
C:\Users\ADMINL~1\AppData\Local\Temp>"\bin\vcredist-2008-sp1-x64.exe" /q
C:\Users\ADMINL~1\AppData\Local\Temp>if errorlevel 3010 echo1>"\etc\reboot"
C:\Users\ADMINL~1\AppData\Local\Temp>del "\bin\vcredist-2008-sp1-x64.exe"
C:\Users\ADMINL~1\AppData\Local\Temp>"\bin\vcredist-2010-x64.exe" /q
C:\Users\ADMINL~1\AppData\Local\Temp>del "\bin\vcredist-2010-x64.exe"
C:\Users\ADMINL~1\AppData\Local\Temp>"\bin\vcredist-2013-x64.exe" /q
C:\Users\ADMINL~1\AppData\Local\Temp>del "\bin\vcredist-2013-x64.exe"
C:\Programmi\qgis>mkdir "C:\ProgramData\Microsoft\Windows\Start
C:\Programmi\qgis>xxmklink "C:\ProgramData\Microsoft\Windows\Start
Menu\Programs\QGIS Wien\MSYS.lnk"       "\apps\msys\msys.bat" " " \
"Minimal SYStem" 7 "\apps\msys\msys.ico"
"xxmklink" non Š riconosciuto come comando interno o esterno,
C:\Programmi\qgis>xxmklink "C:\ProgramData\Desktop\MSYS.lnk"
"\apps\msys\msys.bat" " " \ "Minimal SYStem" 7 "\apps\msys\msys.ico"
C:\Programmi\qgis>textreplace -std -t apps/msys/etc/fstab
C:\Programmi\qgis>dllupdate -oite -copy -reboot "\bin\libeay32.dll"
"dllupdate" non Š riconosciuto come comando interno o esterno,
C:\Programmi\qgis>dllupdate -oite -copy -reboot "\bin\ssleay32.dll"
C:\Programmi\qgis>textreplace -std -t bin\pyuic4.bat
C:\Programmi\qgis>set OSGEO4W_ROOT=\=\\
apps\Python27\Lib\site-packages\PyQt4\pyqtconfig.py
C:\Programmi\qgis>call "\bin\make-bat-for-py.bat"
C:\Programmi\qgis>call "\bin\o4w_env.bat"
C:\Programmi\qgis>path
\bin;C:\ProgramData\Oracle\Java\javapath;\\intra.comune.trento.it\SysVol\intra.comune.trento.it\Policies\{781A54C9-6DD1-4CCE-8D9C-D9C6F9035495}\Machine\Scripts\Shutdown;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program
Files (x86)\IBM\Client Access\Emulator;C:\Program Files
(x86)\IBM\Client Access\Shared;C:\Program Files (x86)\IBM\Client
Access\;C:\Program Files (x86)\Java\jre7\bin;C:\Program
Files\Microsoft SQL Server\110\Tools\Binn\;C:\Program Files
(x86)\Microsoft SDKs\TypeScript\1.0\;C:\Program Files\Microsoft SQL
Server\120\Tools\Binn\;;C:\Program Files
(x86)\Java\jre7\bin;C:\Program Files\Crucial\Storage
Executive;\apps\qgis-ltr\bin
C:\Programmi\qgis>set QGIS_PREFIX_PATH=\=//apps/qgis-ltr
C:\Programmi\qgis>"\apps\qgis-ltr\crssync"
C:\Programmi\qgis>textreplace -std -t bin\qgis-ltr.bat
C:\Programmi\qgis>textreplace -std -t bin\qgis-ltr-browser.bat
C:\Programmi\qgis>REM get short path without blanks
C:\Programmi\qgis>for %i in ("") do set O4W_ROOT=%~fsi
C:\Programmi\qgis>set O4W_ROOT=
"C:\ProgramData\Microsoft\Windows\Start Menu\Programs\QGIS Wien" "QGIS
Desktop 2.8.3" "exec hide \bin\qgis-ltr.bat"
"\apps\qgis-ltr\icons\QGIS.ico"
Browser 2.8.3" "exec hide \bin\qgis-ltr-browser.bat"
"~$folder.desktop$" "QGIS Desktop 2.8.3" "exec hide \bin\qgis-ltr.bat"
"~$folder.desktop$" "QGIS Browser 2.8.3" "exec hide
\bin\qgis-ltr-browser.bat" "\apps\qgis-ltr\icons\QGIS.ico"
C:\Programmi\qgis>textreplace -std -t "\apps\qgis-ltr\bin\qgis.reg"
C:\Programmi\qgis>nircmd elevate "C:\Windows\regedit" /s
C:\Programmi\qgis>textreplace -std -t "\=\\"\apps\Qt4\mkspecs\default\qmake.conf
C:\Programmi\qgis>set OSGEO4W_ROOT=\=/
C:\Programmi\qgis>textreplace -std -t "\=/"\bin\qt.conf
"C:\ProgramData\Microsoft\Windows\Start Menu\Programs\QGIS Wien" "SAGA
GIS (2.1.2)" "exec hide """\bin\saga_gui.bat"" -wx"
"\apps\saga\saga_gui.exe"
"C:\ProgramData\Desktop" "SAGA GIS (2.1.2)" "exec hide
"""\bin\saga_gui.bat"" "\apps\saga\saga_gui.exe"
C:\Programmi\qgis>nircmd shortcut "\bin\nircmd.exe"
"Setup" "exec hide ~q\bin\setup.bat~q -R ~q~q" "\OSGeo4W.ico"
C:\Programmi\qgis>textreplace -std -t bin/setup.bat
C:\Programmi\qgis>textreplace -std -t bin/setup-test.bat
C:\Programmi\qgis>if not 1 == 0 xxmklink
Wien\OSGeo4W Shell.lnk" "\OSGeo4W.bat" " " \ "OSGeo for Windows
command shell" 1 "\OSGeo4W.ico"
"C:\ProgramData\Desktop\OSGeo4W Shell.lnk" "\OSGeo4W.bat" " " \ "OSGeo
for Windows command shell" 1 "\OSGeo4W.ico"
apps\Python27\Lib\site-packages\sipconfig.py
