[Qgis-developer] Compiling ui files with custom widgets creates wrong imports
Anita Graser
anitagraser at gmx.at
Thu Aug 6 00:39:23 PDT 2015
On Thu, Aug 6, 2015 at 9:24 AM, Denis Rouzaud <denis.rouzaud at gmail.com>
wrote:
> You need to have qgis lib in your python path.
> On windows, that would be C:\OSGeo4W\apps\qgis-dev\python\qgis
> To check this, just do "from qgis.gui import *" in python. If you don't
> have an error, then pyuic4 will work properly.
My point is that the plugin needs to work out of the box - and it doesn't.
Usually all paths are set correctly on Win in the OSGeo shell. Only in this
case there is an issue.
Best wishes,
Anita
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150806/40441883/attachment.html>
