[Qgis-developer] QGIS 2.10 - weird black circles
Simó Benedek
universitas87 at gmail.com
Thu Aug 6 01:49:05 PDT 2015
Thank you Anita, after removing every diagram related tag from the qgs
file, everything works well, thank you! In my case it happened with a qgs
file which was saved in 2.10.1, and than after slight modifications it was
saved in 2.6.
2015-08-06 10:32 GMT+02:00 kimaidou <kimaidou at gmail.com>:
> Hi Anita,
> This is it ! I will have to deactivate them for every layer ( looking
> which is corresponding tag and boolean to set to False in the QGS file)
> Thanks
> Michaël
> 2015-08-06 10:28 GMT+02:00 Anita Graser <anitagraser at gmx.at>:
>> Check if diagrams are enabled on the problematic layers. There was/is(?)
>> a bug that enabled diagrams.
>> Best wishes,
>> Anita
>> On Thu, Aug 6, 2015 at 10:18 AM, kimaidou <kimaidou at gmail.com> wrote:
>>> Hi all,
>>> When playing around with projects from 2.8 to 2.10, some users reported
>>> me they encounter weird rendering of their layers. Some black circles are
>>> drawn on top of the layers, like in this image [1]
>>> This happens for point or polygons, and for different method (
>>> classification, single symbol, etc.).
>>> I can manage sometime to get rid of these circles by opening/closing the
>>> layer properties dialog, and checking on/off the layer in the legend.
>>> Anyone has already seen this, and found a solution ? It seems to me it
>>> is related to conversion of old project with 2.10, but I am not sure
>>> Any help appreciated.
>>> Michaël
>>> [1] http://picpaste.com/hlAl8PS8.png
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150806/e8d9c260/attachment.html>
