[Qgis-developer] Compiling ui files with custom widgets creates wrong imports
Denis Rouzaud denis.rouzaud at gmail.com
Thu Aug 6 01:54:08 PDT 2015
Here is an example of a Makefile compiling ui files
https://github.com/3nids/quickfinder/blob/master/Makefile#L52
it's the line with pyuic4 which does the job!
On 08/06/2015 10:33 AM, Anita Graser wrote:
> On Thu, Aug 6, 2015 at 10:10 AM, Denis Rouzaud
> <denis.rouzaud at gmail.com <mailto:denis.rouzaud at gmail.com>> wrote:
>     Never used, I would think it would work directly.
> ​ According to the plugin author the plugin with uic.loadUiTypes works
> on Linux but it certainly does not work on Windows.​
>     But why not adding a new rule to the makefile to compile the ui?
> ​If that's necessary to get custom widgets work on all platforms, why
> not. But I don't know where to start to make that work.
> Best wishes.
> Anita​
>     On 08/06/2015 10:06 AM, Anita Graser wrote:
>>     On Thu, Aug 6, 2015 at 9:44 AM, Denis Rouzaud
>>         Well, how is compiled the UI file?
>>     ​The plugin builder creates a template that uses uic.loadUiType
>>     FORM_CLASS, _ = uic.loadUiType(os.path.join(
>>     os.path.dirname(__file__), 'cartogram_dialog_base.ui'))
>>     ​So the UI is compiled automatically when the plugin starts in QGIS.
>>     Best wishes,
>>     Anita​
>>         Usually, it is done prior to deployment using pyuic4
>>         If pyuic4 was run without the proper python path, you won't
>>         have any error at compilation but the plugin won't work if it
>>         contains QGIS widgets.
>>         Was pyuic4 run in an Osgeo shell?
>>         On 08/06/2015 09:39 AM, Anita Graser wrote:
>>>         On Thu, Aug 6, 2015 at 9:24 AM, Denis Rouzaud
>>>         wrote:
>>>             You need to have qgis lib in your python path.
>>>             On windows, that would be
>>>             C:\OSGeo4W\apps\qgis-dev\python\qgis
>>>             To check this, just do "from qgis.gui import *" in
>>>             python. If you don't have an error, then pyuic4 will
>>>             work properly.
>>>         ​My point is that the plugin needs to work out of the box -
>>>         and it doesn't.
>>>         Usually all paths are set correctly on Win in the OSGeo
>>>         shell. Only in this case there is an issue.
>>>         Best wishes,
>>>         Anita
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150806/3421308c/attachment.html>
