[Qgis-developer] QGIS 2.10.1 Pisa - Read CSV file problem
Neumann, Andreas a.neumann at carto.net
Thu Aug 6 02:30:05 PDT 2015
Don't get me wrong. I am not against fixing it. I was just trying to put
it into perspective. Just because there is one dataset that has these
weird column names it doesn't mean the CSV import tool is broken. You
can just as well advise the StatsSA agency to improve their column names
into something more meaningful - e.g. age_10 - what if you want to join
the data later and you have again column names with numbers? What if
another person takes over the project and has no idea what the numbers
mean without a separate metadata description? What if you want to do
"Save AS" with such a layer and the data format prohibits columns named
with numbers?
Anyway - its not good practice to name columns with numbers. In most
database you will have to escape such column names with quotes or it is
even forbidden.
If you want to have it fixed you have the three options:
- Fix it yourself in the code and provide a pull request
- Pay a developer to fix it to have it fixed in a short time frame
- File a feature request and wait until someone has the time to fix it
Andreas
On 2015-08-06 08:04, Zoltan Szecsei wrote:
> Hi,
> Fine - I did ask for an opinion, and I got one :-)
> The CSV files are from South Africa's 2011 Census - as put out by StatsSA, and exported from SuperCROSS.
> In this particular file, the numeric field names are for the "Age last birthday" of the occupant. (yep, from 0 to 120!!!)
> So in short, I guess there are many, many users of this data - and for me an unnoticed error/deficiency, is still and error/deficiency.
> Whilst I am not too perturbed because I can get around this issue, I figured it was my "civic" duty to raise it.
> Cheers for now,
> Zoltan
> On 2015/08/06 07:56, Neumann, Andreas wrote:
> Hi,
> In my opinion it is quite "special" to name columns with integer numbers. Not what the average GIS user would do. In my own 2-decade GIS career I never had such an issue.
> I am not against fixing this issue, but I don't think it is a serious issue. We have many more important issues in QGIS.
> Andreas
> On 2015-08-06 07:31, Zoltan Szecsei wrote:
> Hi Chris,
> Thanks for the opinion.
> Do I log this as a bug?
> Whilst I am quite happy to write a bash script to parse and alter my 500 CSV files, I do feel that this is likely a more serious issue, as it will affect, I assume a lot of, users that load CSV files to join them to their spatial data.
> Maybe the silence on this is because it either goes unnoticed, or there are many people just doing a work-around.
> Let me know.
> Thanks & regards,
> Zoltan
> On 2015/⁠08/⁠05 02:55, Chris Crook wrote: Hi Zoltan
> I think this could be classed as an error! The source code rejects field names that look like positive numbers (some digits optionally followed by a period and some more digits).
> I can't recall a reason why it should do this. It could be reasonable to require field names to be compatible to database attribute names, but I can't see any need for that within QGIS itself. This can go on a 'to-⁠do' list to fix...
> Cheers
> Chris
> -⁠-⁠-⁠-⁠-⁠Original Message-⁠-⁠-⁠-⁠-⁠
> From: Zoltan Szecsei [mailto:zoltans at geograph.co.za]
> Sent: Tuesday, 4 August 2015 10:27 p.m.
> To: Qgis-developer at lists.osgeo.org
> Subject: [Qgis-⁠developer] QGIS 2.10.1 Pisa -⁠ Read CSV file problem
> Hi,
> Using the above version on Win 7 64 bit, I read a CSV file (as attributes only)
> stipulating that "first record has field names"
> Record 1 is as follows:
> "SALnum","SALnam","1","2","3","4","5","6","7","8","9","10+"
> When I open the attribute table, I see that fields 1 & 2 have names SALnum
> and SALnam, but the rest are called 'Field_3', 'Field_4' and so on.
> When I edit record 1 of this CSV file to look like:
> "SALnum","SALnam","1p","2p","3p","4p","5p","6p","7p","8p","9p","10+p"
> The I get the correct field names (albeit 1p instead of just "1")
> Is this an error, or is there some reason further down the line, that attribute
> tables cannot have 'numeric' field names?
> Thanks and regards,
> Zoltan
> Zoltan Szecsei PrGISc [PGP0031]
> Geograph (Pty) Ltd.
> GIS and Photogrammetric Services
> P.O. Box 7, Muizenberg 7950, South Africa.
> Mobile: +27-⁠83-⁠6004028
> Fax: +27-⁠86-⁠6115323 www.geograph.co.za [1]
> This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
 Geograph (Pty) Ltd.
 Qgis-⁠developer mailing list
http://lists.osgeo.org/mailman/listinfo/qgis-developer [2]
Geograph (Pty) Ltd.
Mobile: +27-83-6004028
Fax: +27-86-6115323 www.geograph.co.za [1]
Links:
[1] http://www.geograph.co.za
[2] http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150806/14758fe0/attachment.html>
