[Qgis-developer] very slow on creating a new empty spatialite db
Ing. Pierluigi De Rosa pierluigi.derosa at gfosservices.it
Fri Aug 7 07:43:11 PDT 2015
Dear all,
I'm experiencing than when I create a new empty spatialite from qgis it
takes long time to do it.
Here belo is the code I tried:
# -*- coding: utf-8 -*-
from qgis.core import *
import qgis.utils
from pyspatialite import dbapi2 as db
import timeit
start = timeit.default_timer()
dbase='/home/pierluigi/Scrivania/db.sqlite'
conn = db.connect(dbase)
cur = conn.cursor()
sql = 'SELECT InitSpatialMetadata()'
cur.execute(sql)
conn.commit()
stop = timeit.default_timer()
print stop - start
If i run this code my pc start swapping so much and to prepare the empty
db (the total variable) it takes 722.3559 sec or better ABOUT 12
MINUTES!!!
Of course the same is if I just save a layer into spatialite format.
Why is this happens?
Is there a work around for my code to speed up che db creation?
I'm running qgis on ubuntu 14.04, qgis 2.8 LTS from launchpad unstable
repo.
Thanks
Pierluigi
________________________________________________________________________
Ing. Pierluigi De Rosa (PhD)
Studio Associato GFOSSERVICES
Presso CAMPUS Via F.lli Cairoli 25 - 06127 Perugia (PG)
fax: 075 7823038
cel: 3497558268
web: www.gfosservices.it
skype: pierluigi.derosa
