[Qgis-developer] QGIS update available plugin and/or ping back plugin
Tim Sutton tim at kartoza.com
Mon Aug 10 14:38:34 PDT 2015
Hi
> On 03 Aug 2015, at 17:18, Richard Duivenvoorde <rdmailings at duif.net> wrote:
> On 03-08-15 12:39, Vincent Picavet (ml) wrote:
>> Repairing this feature, and maybe having an automated background check
>> at startup would be good for this feature.
> Which is actually the same as a pingback, except without an unique
> identifier...
> But I created an issue for the repair:
> http://hub.qgis.org/issues/13178
>>> Can privacy concerning people live with this plan?
>> Not me.
>> Any personal information sent by the user should only be done on a
>> volontary basis.
>> I would agree with this if :
>> * This is optional
>> * This is not activated by default
>> * The installer could ask the user if he wants to send statistics to the
>> QGIS project, with a list of data items sent.
> let's be honest: if you let ME opt out, I opt out....
> We can already generate global figures based on downloads, or plugin
> update requests...
> Found out that access.log of plugins.qgis.org is not rotated, so some
> grepping:
> $ grep "/2014.*/plugins/plugins.xml?qgis=" access.log | awk '{print $1}'
> | sort | uniq | wc -l
> 541711
> $ grep "/2015.*/plugins/plugins.xml?qgis=" access.log | awk '{print $1}'
> | sort | uniq | wc -l
> 546017
> so about half a million unique ip addresses per year? Not sure how this
> makes up for:
> - several installation behind one reverse proxy ip
> - roaming users or dynamic ip addresses
> But... it is something.
> The advantage of adding little more uniqueness info is to get better
> numbers. Making it an option, will not add something to our current setup.
>>> As an argument to allowing these pingbacks, as we/I invest pretty much
>>> time in localisation around QGIS, it would make me feel better if I know
>>> that all this work is actually be used by some people :-)
>> User statistics are indeed very important. Privacy is just way more
>> important, especially in these troubled times. I do think we, as
>> opensource community members, and digital era citizens, have to show the
>> way. Do not ever do things users would consider evil without getting
>> their agreement.
> As said, for me it is rewarding to see that we have a lot of users, or
> that translations are actually used. But I do not want to end up in a
> privacy flame war. If consensus is that privacy is more important, I
> take that.
Yes it has come up many times before and I think a better approach would be self-registration - perhaps we can take a similar approach to the donations popup after clicking download and encourage our users to add themselves to our user map. And also prompt them to do this on ‘first run’ in QGIS. Akbar has been looking, I think, at adding the user map he built for InaSAFE to http://hub.qgis.org to replace the moribund one we have there.
I don’t think it is beyond the realm of possibility that we have 1/2 million installations out there - though there are also questions about reuse rate (e.g. many could have installed once, had a play and then uninstalled).
Regards
Tim
> Regards,
> Richard
> Qgis-developer mailing list
Tim Sutton
Visit http://kartoza.com <http://kartoza.com/> to find out about open source:
* Desktop GIS programming services
* Geospatial web development
* GIS Training
* Consulting Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
Tim is a member of the QGIS Project Steering Committee
Kartoza is a merger between Linfiniti and Afrispatial
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150810/20fc4d55/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150810/20fc4d55/attachment.png>
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150810/20fc4d55/attachment.pgp>
