[Qgis-developer] Troubles with qwtpolar
Sebastiaan Couwenberg sebastic at xs4all.nl
Sun Aug 16 08:39:17 PDT 2015
On 16-08-15 17:23, Andreas Neumann wrote:
> I upgraded a laptop with Ubuntu 15.04 and I can't compile QGIS because
> of qwtpolar. I tried with internal qwtpolar, but it complains that it is
> not compatible with qwt6.1 and above (which seems to be the default in
> Ubuntu 15.04). It also seems like Ubuntu 15.04 doesn't provide a package
> for qwtpolar, so if I turn internal qwtpolar off it complains that it
> can't find qwtpolar.
> What do you recommend to do on Ubuntu 15.04?
Using the -DWITH_QWTPOLAR=OFF CMake option should be sufficient to build
QGIS with Qwt >= 6.1.
The qwtpolar embedded copy needs to be updated to qwtpolar-1.1 for Qwt
>= 6.1 support, see:
http://hub.qgis.org/issues/13156
Kind Regards,
Bas
 GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
