[Qgis-developer] Troubles with qwtpolar
Jürgen E. Fischer
jef at norbit.de
Sun Aug 16 09:05:28 PDT 2015
Hi Andreas,
On Sun, 16. Aug 2015 at 17:23:17 +0200, Andreas Neumann wrote:
> I upgraded a laptop with Ubuntu 15.04 and I can't compile QGIS
> because of qwtpolar. I tried with internal qwtpolar, but it
> complains that it is not compatible with qwt6.1 and above (which
> seems to be the default in Ubuntu 15.04). It also seems like Ubuntu
> 15.04 doesn't provide a package for qwtpolar, so if I turn internal
> qwtpolar off it complains that it can't find qwtpolar.
Did you install libqwt5-qt4-dev? That's what the nightlies use. You could
also just use the nightlies or build packages (which produce a build dir
with the working settings from debian/ in debian/build).
Jürgen
[1] https://htmlpreview.github.io/?https://raw.github.com/qgis/QGIS/master/doc/INSTALL.html#toc11
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150816/2e30dcf6/attachment.pgp>
