[Qgis-developer] Troubles with qwtpolar
J.O. Williams j.o.williams.jow at gmail.com
Sun Aug 16 11:11:47 PDT 2015
Andreas,
I would like to suggest that qwtpolar option be changed to OFF
permanently and use the embedded copy exclusively.  I have had trouble
with option a couple of times and have tried to install the qwtpolar
library.  And have wasted a hour each time trying to reinstall before I
remember the change needed. The library  is no longer being maintained
and is probably dead code.
I also build using Ubuntu 14.04 LTS.
TIA
J.O. Williams
On 08/16/2015 10:01 AM, Andreas Neumann wrote:
> Thanks Bas - this seems to work.
> Andreas
> On 16.08.2015 17:39, Sebastiaan Couwenberg wrote:
>> On 16-08-15 17:23, Andreas Neumann wrote:
>>> I upgraded a laptop with Ubuntu 15.04 and I can't compile QGIS because
>>> of qwtpolar. I tried with internal qwtpolar, but it complains that
>>> it is
>>> not compatible with qwt6.1 and above (which seems to be the default in
>>> Ubuntu 15.04). It also seems like Ubuntu 15.04 doesn't provide a
>>> package
>>> for qwtpolar, so if I turn internal qwtpolar off it complains that it
>>> can't find qwtpolar.
>>> What do you recommend to do on Ubuntu 15.04?
>> Using the -DWITH_QWTPOLAR=OFF CMake option should be sufficient to build
>> QGIS with Qwt >= 6.1.
>> The qwtpolar embedded copy needs to be updated to qwtpolar-1.1 for Qwt
>>> = 6.1 support, see:
>> http://hub.qgis.org/issues/13156
>> Kind Regards,
>> Bas
> Qgis-developer mailing list
