[Qgis-developer] CI testing for OSX
Larry Shaffer larrys at dakotacarto.com
Wed Aug 19 09:56:36 PDT 2015
Hi Nyall,
On Wed, Aug 19, 2015 at 4:33 AM, Nyall Dawson <nyall.dawson at gmail.com>
wrote:
> On 19 August 2015 at 08:43, Larry Shaffer <larrys at dakotacarto.com> wrote:
> > Yeah, the postgres and postgis being preinstalled is a bit of a pain,
> since
> > they do not seem to keep them updated.
> > Looks like, since they *are* installed, you can try skipping them (and
> other
> > non-essential recommended libs) as dependencies with:
> > $ brew install qgis-28 --without-postgis --without-postgresql
> > --without-grass --without-gpsbabel --only-dependencies
> Thanks Larry - this has knocked about 10 minutes off the build time!
> Much appreciated :)
> Still no luck with getting the postgres test working yet though. I
> suspect that Travis has issues with the default postgres installation
> under their OSX containers.
Under a normal Homebrew install of postgres it is not running. If you look
at `brew info postgresql` you will see at the end:
"To load postgresql:
  launchctl load ~/Library/LaunchAgents/homebrew.mxcl.postgresql.plist
Or, if you don't want/need launchctl, you can just run:
  postgres -D /usr/local/var/postgres"
I don't see anything in QGIS/ci/travis/osx that indicates postgres is being
spun up, i.e.:
/usr/local/bin/postgres -D /usr/local/var/postgres
Regarding the GRASS provider tests, I can redo the grass-64 builds so that
there are fresh 'bottles' (compiled binary installs) for quick loading.
Then GRASS is only a ~20 MB download and its tests can be run. Likewise,
GRASS7 ends up only 24 MB. I can work on these bits as needed. I'm away
from my build server (where I generate the bottles) today, though.
Regards,
Larry Shaffer
Dakota Cartography
Black Hills, South Dakota
Nyall
> > That should be the minimum for a Travis CI setup (not tested). The only
> > funky one is '--without-postgresql', which is a hard dependency, but the
> > CMake variable POSTGRES_CONFIG:FILEPATH=/usr/local/bin/pg_config should
> be
> > found by default. It was with my test on 10.9.5. Apple's system-provided
> > postgresql client is woefully outdated.
> > The GRASS provider is part of the unit test suite (for both 6 and 7 if
> > found), but, if skipped, should greatly speed up the CI builds.
> > I just updated the formula with 2.8.3. Let me know if you need me to add
> > more options to it to facilitate the Travis setup.
> > Regards,
> > Larry Shaffer
> > Dakota Cartography
> >> Nyall
> >> > Regards,
> >> > Larry Shaffer
> >> > Dakota Cartography
> >> >> Nyall
> >> >> _______________________________________________
> >> >> Qgis-developer mailing list
> >> >> Qgis-developer at lists.osgeo.org
> >> >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150819/77d3597f/attachment-0001.html>
