[Qgis-developer] Call for applications: QGIS API Documentation Improvement
Jürgen E. Fischer
jef at norbit.de
Thu Aug 20 04:20:16 PDT 2015
Hi Ale,
On Thu, 20. Aug 2015 at 11:42:06 +0200, Alessandro Pasotti wrote:
> Doxygen also accepts RST and we could place python documentation into .sip
> files, maybe a solution would be to include snippets and examples from
> doxygen (.sip is preferred) into the cookbook, leaving the introductory
> material in the cookbook itself interleaved with included examples and
> snippets.
The .sip are maintained by comparing them with the header files
(scripts/sipdiff). So IMHO they should be kept as close to them as possible -
at least in the section with the actual interfaces.
But more verbose sections above or below the actual code shouldn't be a problem
(that part is mostly not in synced anyway).
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150820/e31ec417/attachment.pgp>
