[Qgis-developer] WktExport plugin for QGIS
Geo DrinX geodrinx at gmail.com
Tue Aug 25 08:00:03 PDT 2015
Even,
I noticed that  "Plain Geometry Editor"  plugin   (and also my  "WktExport"
plugin :)   saves  some elements as
" LineStringZ "
that of course have also the Z.
This is good for my use (the 3D  digitizing) ,  but I am asking :   is it a
new of QGIS 2.10,   or it just exists before ?
So, my need is to display these Z, for each point of the lines.   There is
a way to do this ?   I tried with "processing >  SAGA > Shapes-Points >
convert lines to points"  but, the result is a points layer  without Z.
Also,  Layer property panel  do not permits to display the Z value as Label.
Any other suggestion to display Z values ?
Thank you
Roberto
2015-08-25 16:28 GMT+02:00 Even Rouault <even.rouault at spatialys.com>:
> Le mardi 25 août 2015 16:22:13, Geo DrinX a écrit :
> > Side remark. Your plugin probably makes it a bit more convenient, but you
> > > can
> > > already get the geometries in WKT format with "Save as", select CSV and
> > > enter
> > > GEOMETRY=AS_WKT as layer creation option (cf
> > > http://www.gdal.org/drv_csv.html)
> > Touche' ,  Even  :)
> > I do not know that is possible to do the same with save as...   :(
> > BTW,  great !    There is some documentation for this ?   I will browse
> > QGIS manuals.
> > Sure, my method is more immediate, and more convenient for my own use.
> > For the rest of the world, I agree with you :   a generic user, can use
> > "Save as..."   CSV  and enter  "GEOM=ASWKT"
> > and... it does not work !  What is the correct syntax ?  I do not
> > remember:  I need to try again... perhaps:  "GEOMETRY=ASWKT".   No, it do
> > not work again... etcetera.
> Indeed, the good news is that with GDAL 2.0, OGR drivers now have
> metadata. So
> instead/in addition of a free text zone, the list of options could now
> potentially be automatically generated by inspecting driver metadata
> $ ogrinfo --format csv
> Format Details:
>   Short Name: CSV
>   Long Name: Comma Separated Value (.csv)
>   Supports: Vector
>   Extension: csv
>   Help Topic: drv_csv.html
>   Supports: Open() - Open existing dataset.
>   Supports: Create() - Create writeable dataset.
>   Supports: Virtual IO - eg. /vsimem/
>   Creation Field Datatypes: Integer Integer64 Real String Date DateTime
> Time
> <CreationOptionList>
>   <Option name="GEOMETRY" type="string-select" description="how to encode
> geometry fields">
>     <Value>AS_WKT</Value>
>   </Option>
> </CreationOptionList>
> <LayerCreationOptionList>
>   <Option name="SEPARATOR" type="string-select" description="field
> separator"
> default="COMMA">
>     <Value>COMMA</Value>
>     <Value>SEMICOLON</Value>
>     <Value>TAB</Value>
>     <Value>SPACE</Value>
>   </Option>
>   <Option name="LINEFORMAT" type="string-select" description="end-of-line
> sequence" default="LF">
>     <Value>CRLF</Value>
>     <Value>LF</Value>
>   </Option>
> geometry fields">
>     <Value>AS_XYZ</Value>
>     <Value>AS_XY</Value>
>     <Value>AS_YX</Value>
>   </Option>
>   <Option name="CREATE_CSVT" type="boolean" description="whether to create
> a
> .csvt file" default="NO" />
>   <Option name="WRITE_BOM" type="boolean" description="whether to write a
> UTF-8 BOM prefix" default="NO" />
>   <Option name="GEOMETRY_NAME" type="string" description="Name of geometry
> column. Only used if GEOMETRY=AS_WKT" default="WKT" />
> </LayerCreationOptionList>
> <OpenOptionList>
>   <Option name="MERGE_SEPARATOR" type="boolean" description="whether to
> merge
> consecutive separators" default="NO" />
>   <Option name="AUTODETECT_TYPE" type="boolean" description="whether to
> guess
> data type from first bytes of the file" default="NO" />
>   <Option name="KEEP_SOURCE_COLUMNS" type="boolean" description="whether to
> add original columns whose guessed data type is not String. Only used if
> AUTODETECT_TYPE=YES" default="NO" />
>   <Option name="AUTODETECT_WIDTH" type="string-select"
> auto-detect width/precision. Only used if AUTODETECT_TYPE=YES"
> default="NO">
>     <Value>YES</Value>
>     <Value>NO</Value>
>     <Value>STRING_ONLY</Value>
>   </Option>
>   <Option name="AUTODETECT_SIZE_LIMIT" type="int" description="number of
> bytes
> to inspect for auto-detection of data type. Only used if
> default="1000000" />
>   <Option name="QUOTED_FIELDS_AS_STRING" type="boolean" description="Only
> used
> if AUTODETECT_TYPE=YES. Whether to enforce quoted fields as string fields."
> default="NO" />
>   <Option name="X_POSSIBLE_NAMES" type="string" description="Comma
> separated
> list of possible names for X/longitude coordinate of a point." />
>   <Option name="Y_POSSIBLE_NAMES" type="string" description="Comma
> separated
> list of possible names for Y/latitude coordinate of a point." />
>   <Option name="Z_POSSIBLE_NAMES" type="string" description="Comma
> separated
> list of possible names for Z/elevation coordinate of a point." />
>   <Option name="GEOM_POSSIBLE_NAMES" type="string" description="Comma
> separated list of possible names for geometry columns." default="WKT" />
>   <Option name="KEEP_GEOM_COLUMNS" type="boolean" description="whether to
> add
> original x/y/geometry columns as regular fields." default="YES" />
>   <Option name="HEADERS" type="string-select" description="Whether the
> first
> line of the file contains column names or not" default="AUTO">
>     <Value>YES</Value>
>     <Value>NO</Value>
>     <Value>AUTO</Value>
>   </Option>
> </OpenOptionList>
> > Yes, I think my plugin can be useful to all of us "QGIS dummies"    :)
> > If you think, I can insert a message that explains:  "You can also use
> > 'Save as... CSV    GEOMETRY=AS_WKT'
> > Of course, I am joking.
> > Happy holidays
> > Roberto
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150825/6af1dee6/attachment-0001.html>
