[Qgis-developer] Processing Modeler regression Unable to open datasource of intermediate results
Anita Graser
anitagraser at gmx.at
Wed Aug 26 23:23:45 PDT 2015
On Aug 26, 2015 4:47 PM, "Bernd Vogelgesang" <bernd.vogelgesang at gmx.de>
wrote:
> Am 26.08.2015, 09:08 Uhr, schrieb Anita Graser <anitagraser at gmx.at>:
> I reported this already some weeks ago: https://hub.qgis.org/issues/13174
> My suspicion was, that this is related to GDAL processes, cause all
others seem to run fine.
Thanks Bernd,
Must have missed that the first time.
I guess some file handling must have changed between processing 2.9 and
2.10 that broke it.
Best wishes
Anita
>> Algorithm dissolve starting...
>> Prepare algorithm: QGISFIXEDDISTANCEBUFFER_1
>> Running Fixed distance buffer [1/2]
>> Parameters: INPUT
=C:/Users/agraser/Downloads/qgis_sample_data/shapefiles/popp.shp, DISTANCE
=10000, SEGMENTS =5, DISSOLVE =True
>> Converting outputs
>> OK. Execution took 67.825 ms (1 outputs).
>> Prepare algorithm: GDALOGRDISSOLVEPOLYGONS_1
>> Running Dissolve polygons [2/2]
>> Parameters: INPUT_LAYER
=C:\Users\agraser\AppData\Local\Temp\processing\7f77fa47bcec4799818d1f5ea41cc8a9\OUTPUT.shp,
GEOMETRY =geometry, FIELD =TYPE, MULTI =False, FIELDS =False, COUNT =False,
AREA =False, STATS =False, STATSATT =TYPE, OPTIONS =
>> GDAL command:
>> cmd.exe /C ogr2ogr.exe
C:\Users\agraser\AppData\Local\Temp\processing\a44629a1c1f34bc4bf9d26ed974f2bb6\OUTPUTLAYERALGGDALOGRDISSOLVEPOLYGONS1.shp
OUTPUT -dialect sqlite -sql "SELECT ST_Union(geometry),TYPE FROM 'OUTPUT'
GROUP BY TYPE" -explodecollections
>> GDAL command output:
>> FAILURE:
`:\Users\agraser\AppData\Local\Temp\processing\7f77fa47bcec4799818d1f5ea41cc8a9\OUTPUT.sh'
with the following drivers.
>> -> ESRI Shapefile
>> -> MapInfo File
>> -> UK .NTF
>> -> SDTS
>> -> TIGER
>> -> S57
>> -> DGN
>> -> VRT
>> -> REC
>> -> Memory
>> -> BNA
>> -> CSV
>> -> NAS
>> -> GML
>> -> GPX
>> -> KML
>> -> GeoJSON
>> -> Interlis 1
>> -> Interlis 2
>> -> GMT
>> -> GPKG
>> -> SQLite
>> -> ODBC
>> -> WAsP
>> -> PGeo
>> -> MSSQLSpatial
>> -> OGDI
>> -> PostgreSQL
>> -> MySQL
>> -> PCIDSK
>> -> OpenFileGDB
>> -> XPlane
>> -> AVCBin
>> -> AVCE00
>> -> DXF
>> -> Geoconcept
>> -> GeoRSS
>> -> GPSTrackMaker
>> -> VFK
>> -> PGDump
>> -> OSM
>> -> GPSBabel
>> -> SUA
>> -> OpenAir
>> -> PDS
>> -> WFS
>> -> HTF
>> -> AeronavFAA
>> -> Geomedia
>> -> EDIGEO
>> -> GFT
>> -> GME
>> -> SVG
>> -> CouchDB
>> -> Idrisi
>> -> ARCGEN
>> -> SEGUKOOA
>> -> SEGY
>> -> XLS
>> -> ODS
>> -> XLSX
>> -> ElasticSearch
>> -> PDF
>> -> Walk
>> -> CartoDB
>> -> SXF
>> Converting outputs
>> OK. Execution took 0.125 ms (1 outputs).
>> Model processed ok. Executed 2 algorithms total
>> Converting outputs
>> Loading resulting layers
> Bernd Vogelgesang
> Siedlerstraße 2
> 91083 Baiersdorf/Igelsdorf
> Tel: 09133-825374
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150827/d928f6a9/attachment.html>
