[Qgis-developer] Processing framework - background processing
Marcus Santos
mvcs at me.com
Thu Aug 27 03:14:49 PDT 2015
Hi Roberto,
You just have to put the processing code into your QGIS directory. Should be something like this:
~/.qgis/python/plugins/processing
After that you can run the QGIS as you normally do, without having to compile anything.
Be aware that the multithreading is not working with all algorithms.
Cheers,
Marcus
No dia 27/08/2015, às 11:01, Geo DrinX <geodrinx at gmail.com> escreveu:
>> no you don't need to recompile whole QGIS, just grab Processing code.
> I have QGIS 2.10.1 installed. I have no any developer version. Can I install Processing code "grabbing" in what way ?
> What I have to do, exactly ? Can you send me the link ? I need to recompile only Processing code ?
> Thank you and sorry if I am a little "dummy" :)
> Roberto
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150827/608ccbe2/attachment.html>
