[Qgis-developer] Processing framework - background processing
Geo DrinX geodrinx at gmail.com
Thu Aug 27 07:01:54 PDT 2015
Ok.
Thank you all.  I have done  :)
Sorry, but I am slow on the uptake   :)
Now, I am following this:
https://www.youtube.com/watch?v=V-CJCnKw89U
Do you suggest me other  multithread  functions active to test ?
Thank you again
Roberto
2015-08-27 15:40 GMT+02:00 Alexander Bruy <alexander.bruy at gmail.com>:
> Hi Roberto,
> again, there is no need to recompile.
> All you need is to grab Processing code from the repository mentioned
> by Marcus [0]. Not all code, only Processing. Look at the python/plugins
> directory. Then put this code into your QGIS plugins directory. Usually
> this
> is ~/.qgis2/python/plugins. That's all.
> After this you can start QGIS as usual and test.
> [0] https://github.com/mvcsantos/QGIS
> 2015-08-27 16:36 GMT+03:00 Geo DrinX <geodrinx at gmail.com>:
> > Marcus,
> > the ZIP you indicated is a complete QGIS source .
> > Where  is your    Processing   installable on Windows ?   Do I need to
> > recompile something ?
> > I'm afraid I do not understand what I need to do.    Could you please
> > explain me the singular steps ?
> > Thank you
> > Roberto
> > 2015-08-27 14:12 GMT+02:00 Marcus Santos <mvcs at me.com>:
> >> On 27 Aug 2015, at 11:48, Geo DrinX <geodrinx at gmail.com> wrote:
> >> 2015-08-27 12:36 GMT+02:00 Marcus Santos <mvcs at me.com>:
> >>> Oh sorry, this is the link:
> >>> Look for the master branch, you'll find the code there.
> >> OK.  I will unpack the ZIP under my:
> >> c:\Users\rrr\.qgis2\python\plugins\
> >> correct ?
> >> Exactly, you just need to put the processing plugin under the plugins
> >> directory.
> >> But, it do not conflict with the default installed
> >> c:\PROGRA~1\QGISPI~1\apps\qgis\.\python\plugins\processing
> >> Versione disponibile: 2.10.1 (in Repository plugin ufficiale QGIS)
> >> Well, I’m not sure if it works the same way on Windows but I suppose
> it’s
> >> the same.
> >> Perhaps, your version will deactivate  the default version
> automatically,
> >> or  need I to deactivate it manually, before to install your ?
> >> I guess so.
> >> Thank you for testing the new implementation.
> >> I'm looking forward to hear about the multithreading behaviour on
> Windows
> Alexander Bruy
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150827/b978e9c0/attachment.html>
