[Qgis-developer] [Processing] translate parameter selection dropdown contents
Arnaud Morvan
arnaud.morvan at camptocamp.com
Thu Aug 27 09:17:43 PDT 2015
Hello,
without further notice, I will work on processing dropdown parameter
translation next week, that is:
modify all algorithms in the QGIS group, like this :
https://github.com/arnaud-morvan/QGIS/commit/0286c3d95dffeee65ff7a6b7a69919d700815e4b
and make a Pull Request
Best Regards
Arnaud
Le 26/08/2015 14:50, Arnaud Morvan a écrit :
> Hello,
> In processing algorithms, I want to translate the ParameterSelection
> dropdown contents.
> I've tested two possibilities on SpatialJoin, which both operate,
> and I want to get review before editing all algorithms :
> First solution: use of QCoreApplication.translate('SpatialJoin', ...)
> in the class header:
> https://github.com/arnaud-morvan/QGIS/commit/0daefe838c2b02c8a1bbeffdec551f578424b592
> With this form we have to specify context for each string.
> Translation is effectively made at import time because language is
> set before loading processing plugin.
> Second solution: use self.tr method in the defineCharacteristics method :
> With this form, we use the self.tr method at runtime on each
> defineCharacteristics call, like it is the case for name, group and
> parameters names.
> I think that it is better to make translations at runtime, that is, in
> the defineCharacteristics method.
> Does anyone have an opinion on this ?
> Arnaud
