[Qgis-developer] QGIS 2.10.1 currently uninstallable on Debian sid?
Jürgen E. Fischer jef at norbit.de
Fri Aug 28 00:54:13 PDT 2015
Hi Paolo,
On Fri, 28. Aug 2015 at 09:41:14 +0200, Paolo Cavallini wrote:
> Even more seriously: I cannot go back to neither 2.8.3 nor .2.
Not surprising.  Old packages won't work, because their dependencies are gone
and new ones won't build, because the newer build dependencies are currently
partly uninstallable.
> Any other solution?
Um, you shouldn't be using unstable, if you are not prepared to handle this ;)
Try building from source.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150828/a15aa54b/attachment.pgp>
