[Qgis-developer] 2.6 strange behaviour with editing boolean field using checkbox + postgis
Denis Rouzaud
denis.rouzaud at gmail.com
Fri Aug 28 06:20:42 PDT 2015
Note sure for te technical details, but instead of true/false, I have t
and f as checked and unchecked values.
On 08/28/2015 03:11 PM, Rémi Cura wrote:
> Hey,
> some strange behaviour here (2.6) :
> In a postgis layer over a postgis view
> one of the view field is a boolean
> I chose the checkbox for editing this field.
> checked is "true", unchecked is "false" , without the quote signs.
> When adding a new geometry, all works as intended, the row inserted
> into the database is the correct one.
> But when trying to get info about the geometry (arrow with the
> question mark), it generates an error :
> 1 cursor states lost.
> SQL:
> DECLARE qgis_12 BINARY CURSOR FOR
> SELECT st_asbinary("geom",'NDR')
> ,boolout("positionning_absolute")
> ,"gid"::text
> ,"type"::text
> ,"positionning_offset_type"::text
> ,"positionning_offset"::text
> ,"positionning_orientation_type"::text
> ,"positionning_orientation"::text
> ,"curv_dist"::text
> FROM "street_amp"."editing_street_object"
> WHERE boolout("positionning_absolute")='t'
> Résultat: 7 (
> ERROR: operator does not exist: cstring = unknown
> LINE 1: ...ng_street_object" WHERE boolout("positionning_absolute")='t'
> HINT: No operator matches the given name and argument type(s). You
> might need to add explicit type casts.
> I don't understand the need to use the boolout function,
> it works simply without it, and if you want to be extra sure,
> you could cast the text to boolean safely (it is not necessary tough)
> WHERE "positionning_absolute"='t'::boolean
> Cheers,
> Rémi-C
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150828/db837ff2/attachment.html>
