[Qgis-developer] is python2 still supported by qgis 2.12 ?
J.O. Williams j.o.williams.jow at gmail.com
Sat Dec 5 15:13:31 PST 2015
List,
This fix my problem too.  I now have only two problems with "make test"
instead of 60+.
I just had update "apt-get install python-qt4-sql".  I didn't have to
run the install for "libqt4-sql".
My OS is Ubuntu 15.10 and is a 3 week old version upgrade. (I am having
to reinstall a lot of other software as well).
NAME="Ubuntu"
VERSION="15.10 (Wily Werewolf)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 15.10"
VERSION_ID="15.10"
The errors from the "make test" are:
99% tests passed, 2 tests failed out of 166
Total Test time (real) = 119.94 sec
The following tests FAILED:
      64 - qgis_networkcontentfetcher (Failed)
     144 - PyQgsNetworkContentFetcher (Failed)
Errors while running CTest
Makefile:116: recipe for target 'test' failed
make: *** [test] Error 8
I don't have any flavor of any GIS server on my network.
Current build is:
QGIS version
2.12.1-Lyon
QGIS code revision
16760fd <https://github.com/qgis/QGIS/commit/16760fd>
Compiled against Qt
4.8.6
Running against Qt
4.8.6
Compiled against GDAL/OGR
1.11.2
Running against GDAL/OGR
1.11.2
Compiled against GEOS
3.5.0-CAPI-1.9.0
Running against GEOS
3.5.0-CAPI-1.9.0 r4084
PostgreSQL Client Version
9.4.5
SpatiaLite Version
4.3.0
QWT Version
5.2.3
PROJ.4 Version
491
QScintilla2 Version
2.9
I used the following to build my current version and it was a virgin git
pull and build without the DEBUG.  I use "make -j 6" for my builds.
git clone -b release-2_12 --single-branchhttps://github.com/qgis/QGIS.git  QGIS_2_12
cd QGIS_2_12
mkdir qgis-2.12
cd qgis-2.12/
ccmake .. #There in the CMAKE_BUILD_TYPE line I entered "Debug"
make
I make two changes for the "ccmake .." and they are ~/apps for the software location
and...
QWT_POLAR as internal.
Starting qgis from the command line gives:
and error box with a traceback with the following:
ImportError: No module named osgeo
and 2nd, the following in an error box:
Unable to load GdalTools plugin.
The required "osgeo [python-gdal]" module is missing.
Install it and try again.
and qgis starts normally with the following dumped to the command line:
Warning: loading of qgis translation failed [/home/jow/apps/share/qgis/i18n//qgis_en_US]
Warning: loading of qt translation failed [/usr/share/qt4/translations/qt_en_US]
Warning: QCss::Parser - Failed to load file  "/style.qss"
Warning: QVariantMap DBusMenuExporterDBus::getProperties(int, const QStringList&) const: Condition failed: action
ERROR 4: `/initrd.img' not recognised as a supported file format.
The only problem I see is the ERROR 4:.  Why does qgis want to know about Linux boot disk image?  Which in my case is a "ln -s" to the real file in the /boot directory.
I haven't tried to chase the other two error box problems (so they might not be a problem).
This is an FYI post to the list developers.
Thanks for your great work.
J.O. Williams
On 12/02/2015 08:53 AM, Sandro Santilli wrote:
> On Wed, Dec 02, 2015 at 04:51:03PM +0100, Luigi Pirelli wrote:
>> libqt4-sql
>> and
>> python-qt4-sql
> Thanks! Installing python-qt4-sql fixed the issue.
> --strk;
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151205/271c0fa4/attachment.html>
