[Qgis-developer] Processing & SAGA 2.2.2
Sebastiaan Couwenberg
sebastic at xs4all.nl
Fri Dec 11 14:17:57 PST 2015
On 10-12-15 15:02, Paolo Cavallini wrote:
> Il 10/12/2015 16:52, Victor Olaya ha scritto:
>> Paolo, are you using the master version? SAGA 2.2.2 is harcoded as a
>> supported version, and all higher version should be supported
> Not, 2.10.3; same with 2.6: on QGIS 2.8.4.
In the git repository only the master & release-2_12 branches support
SAGA 2.2 looking at the history of python/plugins/processing/algs/saga/.
It would be great if this can be backported for QGIS 2.8.5. That would
enable us to close Debian Bug #807339 which also reports the lack of
support for SAGA 2.2 as found in Debian testing & unstable. Fortunately
the qgis backport is not affected because jessie ships with SAGA 2.1.2.
Kind Regards,
Bas
GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146 50D1 6750 F10A E88D 4AF1
