[Qgis-developer] Processing scripts in stand-alone Python scripts
Anita Graser
anitagraser at gmx.at
Tue Dec 15 01:36:00 PST 2015
On Mon, Nov 30, 2015 at 5:16 PM, Victor Olaya <volayaf at gmail.com> wrote:
> The issue is that the "default" folder is based on the location of the
> parent app (if I am not wrong). I can probably move it to somewhere in
> .qgis2 instead. But if there is a manually entered path, then it will
> not use the default one, that's only used if no custom configuration
> has been done.
> Let me check and will see how to fix this.
Hi Victor,
Have you had chance yet to look into this? I can work with a work-around
for now but would be great to see this cleared up.
Thanks and best wishes,
Anita
> 2015-11-30 15:23 GMT+01:00 Anita Graser <anitagraser at gmx.at>:
> > On Fri, Nov 27, 2015 at 3:53 PM, Anita Graser <anitagraser at gmx.at>
> wrote:
> >> On Fri, Nov 27, 2015 at 8:58 AM, Victor Olaya <volayaf at gmail.com>
> wrote:
> >>> I think this must be related to the configuration of the plugins
> folder.
> >>> The script provider reads scripts in the scripts folder, which is
> >>> configured as an option. Maybe that setting is not available in your
> >>> stand-alone script...since it is stored using QSettings. You can check
> >>> it calling ScriptUtils.scriptsFolder()
> >> from processing.script.ScriptUtils import *
> >> print ScriptUtils.scriptsFolder()
> >> if run in stand-alone, returns a wrong folder:
> >> /home/agraser/temp/standaloneprocessing/processing/scripts
> >> (/home/agraser/temp/standaloneprocessing is the location of my
> stand-alone
> >> script)
> >> instead of the correct folder in the QGIS console: u'
> >> /home/agraser/.qgis2/processing/scripts'.
> >> Seems like we are getting closer to where the real issue is hiding. Imho
> >> it makes little sense that the paths appear relative to the stand-alone
> >> script's location.
> > If I move the stand-alone script into
> > /home/agraser/.qgis2/, I can execute it and it finds my custom Processing
> > script.
> > In any other location the script fails because Processing uses the wrong
> > scripts folder.
> > I'd rather not hard-code the scripts folder. Do you have an idea how to
> make
> > Processing use its "default" scripts folder rather than something in the
> > stand-alone script's location?
> > Anita
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151215/0fb8e81b/attachment-0001.html>
