[Qgis-developer] QGIS server bad creashes
Alessandro Pasotti
apasotti at gmail.com
Tue Dec 22 07:24:30 PST 2015
2015-12-22 16:18 GMT+01:00 Paolo Cavallini <cavallini at faunalia.it>:
> Hi all,
> a new installation of qgis server is repeatedly crashing here[0]. The
> same projects are working with a previous installation. I also tried
> rebuilding a project from scratch, and it works with just one layer, as
> I add more I get the crash.
> Any hint? Seems a pretty serious issue.
> Thanks.
> [0]
> terminate called after throwing an instance of 'QgsCsException'
> [Tue Dec 22 16:14:38.084549 2015] [fcgid:warn] [pid 6313:tid
> 139918316934912] [client 127.0.0.1:54594] mod_fcgid: error reading data,
> FastCGI server closed connection
> [Tue Dec 22 16:14:38.084594 2015] [core:error] [pid 6313:tid
> 139918316934912] [client 127.0.0.1:54594] End of script output before
> headers: qgis_mapserv.fcgi
> 2015-12-22 16:14:38 79.1.153.81 warning 2015-12-22 16:14:38 [2]
> file_get_contents(
> http://127.0.0.1/cgi-bin/qgis_mapserv.fcgi?map=%2Fhome%2Flizmap_data%2Fgeosisma0.qgs&request=GetCapabilities&service=WMS&version=1.3.0
> failed to open stream: HTTP request failed! HTTP/1.1 500 Internal Server
> Error
> /var/www/lizmap-web-client-2.12.2/lizmap/modules/lizmap/classes/lizmapCache.class.php
> 87
> [Tue Dec 22 16:14:43.280192 2015] [fcgid:error] [pid 6311:tid
> 139918472628096] mod_fcgid: process
> /usr/lib/cgi-bin/qgis_mapserv.fcgi(6378) exit(communication error), get
> unexpected signal 6
Is it happening with master or 2.12 ?
I've also seen master crashing quite often recently, but the symptoms are
different, see: http://hub.qgis.org/issues/14001
I spent one day to identify the offending commit but I couldn't track it
down yet :(
Alessandro Pasotti
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151222/13d346b8/attachment.html>
