[Qgis-developer] Warning which failed travis build
René-Luc Dhont
rldhont at gmail.com
Thu Dec 24 04:59:53 PST 2015
Hi devs,
The last commit on master provides a failed on travis build. A warning
provides it.
https://travis-ci.org/qgis/QGIS/builds/98617711
http://dash.orfeo-toolbox.org/index.php?project=QGIS&filtercount=1&showfilters=1&field1=buildname/string&compare1=63&value1=8f29f28d5c5f3f24db40b5183152db0b5b425562&date=2015-12-24
src/providers/ogr/qgsogrexpressioncompiler.cpp:51:12: warning:
enumeration values 'ntInOperator', 'ntLiteral', and 'ntColumnRef' not
handled in switch [-Wswitch]
Can I added the line removed from
default:
return QgsSqlExpressionCompiler::compileNode( node, result );
To fix it ?
Regards,
