[Qgis-developer] How to write tests for Processing scripts?
Anita Graser
anitagraser at gmx.at
Sun Feb 1 03:17:20 PST 2015
I'm trying to write tests for Processing scripts but I'm stuck because
runalg() throws "Error: Algorithm not found". Alglist() also seems unable
to find algorithms from my user script while it manages to find SAGA, GRASS
and co.
Am I missing something or is this a bug?
Code so far is:
import os, sys, glob
import unittest
import numpy as np
# Prepare the environment
from qgis.core import * # qgis.core must be imported before PyQt4.QtGui!!!
from PyQt4.QtGui import *
app = QApplication([])
QgsApplication.setPrefixPath("C:\\OSGeo4W64\\apps\\qgis",True)
QgsApplication.initQgis()
# Prepare processing framework
sys.path.append( "C:\\OSGeo4W64\\apps\\qgis\\python\\plugins" )
from processing.core.Processing import Processing
from processing import runalg, alglist
class TestMorans(unittest.TestCase):
def test_morans(self):
Processing.initialize()
np.random.seed(12345)
alglist('moran')
result =
runalg("script:morans","C:/Users/anita_000/Documents/GitHub/QGIS-Processing-tools/test/data/stl_hom.shp","HR8893","rook")
i = result['i']
self.assertEqual(i,0.24365582621771659)
if __name__ == '__main__':
unittest.main()
Thanks and best wishes,
Anita
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150201/c68dd514/attachment.html>
