[Qgis-developer] How to scale a polygon from pyQgis
Martin Dobias
wonder.sk at gmail.com
Fri Feb 6 04:04:23 PST 2015
Hi
>From QGIS 2.8 there is QgsGeometry.transform() method that works with
QTransform. The following code will scale the sample line segment:
from PyQt4.QtGui import QTransform
g = QgsGeometry.fromPolyline([QgsPoint(-1,0),QgsPoint(1,0)])
g.transform( QTransform().scale(2,2) )
print g.asPolyline()
The code will print [(-2,0), (2,0)]
Cheers
Martin
On Fri, Feb 6, 2015 at 6:53 PM, Geo DrinX <geodrinx at gmail.com> wrote:
> Hello,
> I need to scale a polygon from python code.
> An extract of source code is the following :
> for feat in iter:
> geom = feat.geometry()
> rect = geom.boundingBox()
> x1 = rect.xMinimum()
> y1 = rect.yMinimum()
> x2 = rect.xMaximum()
> y2 = rect.yMinimum()
> xc = (x2 + x1) / 2.0
> yc = (y2 + y1) / 2.0
> elem = geom.asPolygon()
> fat = float(scale) / 100.
> for i in range(geom.exportToWkt().count(',')):
> vertex = geom.vertexAt(i)
> x,y = vertex.x(),
> vertex.y()
> xR, yR = x-xc , y-yc
> xS, yS = xR*fat, yR*fat
> xT, yT = xS + xc, yS + yc
> geom.moveVertex(xT, yT, i)
> Because the polygon do not change, sure I miss something, to save the
> modified element, also if the layer is in editing.
> Someone could help me to understand what I wrong ?
> Thank you
> Roberto
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150206/697e7659/attachment.html>
