[Qgis-developer] What happened to processing.runalg?
Tim Sutton tim at kartoza.com
Fri Feb 6 08:29:38 PST 2015
Hi
Ah thanks for the feedback Victor and Arnaud!
Regards
Tim
On Fri, Feb 6, 2015 at 3:58 PM, Victor Olaya <volayaf at gmail.com> wrote:
> the core methods should not change...and definitely not the runalg method,
> which is likely to be the most important one.
> This is clearly a blocker and has to be reverted.
> 2015-02-06 14:52 GMT+01:00 Arnaud Morvan <arnaud.morvan at camptocamp.com>:
>> I've just meet the same problem
>> it comes from this commit :
>> https://github.com/qgis/QGIS/commit/956c155e8f45cb1a0fc4c5d6204f607f80edc6b0#diff-111
>> some imports where removes from processing.__init__.py in context of a
>> pep8 check
>> this is the source of the regression
>> Arnaud
>> Le 06/02/2015 14:41, Tim Sutton a écrit :
>>  Hi All
>>  Once of our tests in InaSAFE fails against master (see below). Can
>> someone tell me where runalg went, and more broadly which parts of the
>> processing framework can be relied of as API compatible between releases? I
>> guess more and more people will start relying on its API and we should make
>> it clear what the best practice is.
>>  Thanks!
>>  Regards
>>  Tim
>> ERROR: Test if line aggregation works
>> Traceback (most recent call last):
>>   File
>> "/home/timlinux/dev/python/inasafe-dev/safe/impact_statistics/test/test_aggregator.py",
>> line 596, in test_line_aggregation
>>     impact_layer_attributes=impact_layer_attributes)
>>   File
>> line 338, in _aggregate
>>     aggregator.aggregate(impact_layer)
>>   File
>> "/home/timlinux/dev/python/inasafe-dev/safe/impact_statistics/aggregator.py",
>> line 527, in aggregate
>>     qgis_impact_layer, safe_impact_layer)
>>   File
>> line 634, in _aggregrate_vector_impact
>>     self._aggregate_line_impact(safe_impact_layer)
>>   File
>> line 920, in _aggregate_line_impact
>>     res = self.processing.runalg('qgis:intersection',
>> AttributeError: 'module' object has no attribute 'runalg'
>>  Tim Sutton
>> Visit http://kartoza.com to find out about open source:
>>  * Desktop GIS programming services
>>  * Geospatial web development
>> * GIS Training
>> * Consulting Services
>>  Skype: timlinux Irc: timlinux on #qgis at freenode.net
>>  Tim is a member of the QGIS Project Steering Committee
>> Kartoza is a merger between Linfiniti and Afrispatial
>> Qgis-developer mailing listQgis-developer at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton
* GIS Training
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150206/9f837f0a/attachment.html>
