[Qgis-developer] Compression in libpq?
Vincent Picavet - ML
vincent.ml at oslandia.com
Fri Feb 13 07:06:01 PST 2015
Another option is to use SSL, which since version 0.9.8 uses compression by
default. In this case you do not need any specific software neither tunnels.
SSH tunnels are a good solution too though.
Setting up a VPN with compression activated is another option.
Just be aware that compressing compressed data is useless, so better choose a
single option and stick to it.
Vincent
Le vendredi 13 février 2015, 11:18:23 Jean-Roc Morreale a écrit :
> The connections are made through KiTTY which create a ssh tunnel, all
> the applications then connect to the distant postgresql server like a
> local one with the bonus of encryption, compression and no application
> specific setup (even if I would love having an unblocked 5432 port).
> Le 2015-02-13 10:35, Andreas Neumann a écrit :
> > Hi Jean-Roc,
> > Thanks about this hint. I am vaguely aware about this option with pg
> > connections through ssh with gzip. But I did not try it. Do you have
> > any pointers how to set this up?
> > Anyway - having this built in to our existing software without having
> > to set up ssh connections would be a big plus.
> > Thanks,
> > Andreas
> > On 13.02.2015 10:31, Jean-Roc Morreale wrote:
> >> Andreas, did you you try to setup these connection over ssh ? ssh -C
> >> uses gzip
> >> Le 2015-02-13 10:26, Andreas Neumann a écrit :
> >>> Hi,
> >>> Just came across this:
> >>> http://michael.otacoo.com/postgresql-2/postgres-9-5-feature-highlight-pg
> >>> lz-compression-libpqcommon/ This read is very technical.
> >>> Question: does this mean that a future libpq will support
> >>> compression?
> >>> I think this would be very interesting for us, esp. if you work with
> >>> PostgreSQL connections through slower network connections. I always
> >>> found remote Postgis connections that are not on the same LAN quite
> >>> slow.
> >>> Any comments?
> >>> Andreas
> Qgis-developer mailing list
Vincent Picavet - Gérant Oslandia
www.oslandia.com
