[Qgis-developer] commit change in geometry produce fatal error
Lionel Atty
Lionel.Atty at ign.fr
Sat Feb 14 08:51:17 PST 2015
Hi !
I work with Remi-C on this project/plugin QGIS.
What we do now:
- Connect on the signal : 'currentLayerChanged(QgsMapLayer*)' on QgisInterface to track the current layer and the switching layer event
- On the current layer : we use the signal 'layerModified()' to detect modification on current layer -> we try to commitChanges this layer
The result is ... good but we have a problem when we use multiple selection (nodes) with 'Node Tool'. (single selection work fine)
A hard-crash QGIS appear.
GDB indicate a problem with NodeTools and the method 'deselectAllVertexes'
Here a short view of gdb stack:
Program received signal SIGSEGV, Segmentation fault.
0x000000000066d9e6 in QgsSelectedFeature::deselectAllVertexes() ()
(gdb) where
#0 0x000000000066d9e6 in QgsSelectedFeature::deselectAllVertexes() ()
#1 0x000000000066bd35 in QgsMapToolNodeTool::canvasReleaseEvent(QMouseEvent*) ()
#2 0x00007ffff3b8c8b8 in QgsMapCanvas::mouseReleaseEvent(QMouseEvent*) () from /usr/lib/libqgis_gui.so.2.6.1
#3 0x00007ffff245c50a in QWidget::event(QEvent*) () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#4 0x00007ffff27fdfce in QFrame::event(QEvent*) () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#5 0x00007ffff2a097b9 in QGraphicsView::viewportEvent(QEvent*) () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#6 0x00007ffff3073646 in QCoreApplicationPrivate::sendThroughObjectEventFilters(QObject*, QEvent*) ()
from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
#7 0x00007ffff240ce0c in QApplicationPrivate::notify_helper(QObject*, QEvent*) () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#8 0x00007ffff24135dd in QApplication::notify(QObject*, QEvent*) () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#9 0x00007ffff41ebcab in QgsApplication::notify(QObject*, QEvent*) () from /usr/lib/libqgis_core.so.2.6.1
#10 0x00007ffff30734dd in QCoreApplication::notifyInternal(QObject*, QEvent*) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
#11 0x00007ffff2412d93 in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
We use QGIS 2.6 (try with 2.7) Python 2.7, on Linux Ubuntu x64 & Windows 7 x64.
The data provider for the Vector Layer is memory.
Regards,
Lionel-A
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150214/0f00131c/attachment.html>
