[Qgis-developer] Temporary memory layers: wrong dialog size
Nyall Dawson
nyall.dawson at gmail.com
Tue Feb 24 15:49:14 PST 2015
On 24 February 2015 at 23:07, Paolo Cavallini <cavallini at faunalia.it> wrote:
> Also, when adding an element the attribute popup appears, but since
> field cannot be added during creation, the window is useless and
> annoying: should the popup be suppressed, or better give the user to
> opportunity to add fields?
See some discussion in https://hub.qgis.org/issues/10775 . However, I
think the form *should* be suppressed in this case, which
https://github.com/qgis/QGIS/pull/1925 implements.
Thoughts?
Nyall
