[Qgis-developer] QGIS 2.6: .ui form window size
Matthias Kuhn matthias at opengis.ch
Tue Jan 6 08:45:26 PST 2015
I can't see your code, it seems to be swallowed by something.
You could try to add after the resize also the following line (untested
experiment)
dialog.window().saveGeometry()
Matthias
On 01/06/2015 05:33 PM, Guillaume wrote:
> Hi Matthias,
> Thank you for your quick response.
> This code works when I click resize button (open) I created , thanks.
> But at first opening of form window is not the right size as if function was
> not read ...
> Here is my code structure:
> Strange is not it?
> Regards,
> Guillaume
> View this message in context: http://osgeo-org.1560.x6.nabble.com/QGIS-2-6-ui-form-window-size-tp5180053p5180211.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
