[Qgis-developer] About metadata.txt plugin (new) syntax
Richard Duivenvoorde
rdmailings at duif.net
Sun Jan 11 11:50:32 PST 2015
Roberto,
what I read here:
- in your metadata.txt you had 'true'
- but in the form with which you uploaded it, you checked false
(or the other way around)
so: there was a mismatch between what was said in metadata.txt and the
upload form and we do not know which one is correct?
- the experimental flag is required???
>From this docs:
http://docs.qgis.org/testing/en/docs/pyqgis_developer_cookbook/plugins.html#plugin-metadata
it should NOT be...
maybe Alessandro knows better?
Regards,
On 11-01-15 17:43, Geo DrinX wrote:
> Hello,
> I noticed that something must be changed in metadata.txt syntax.
> Inserting a plugin in repository, now it returns this error:
> "There were errors reading plugin package (please check also your
> plugin's metadata).
> The 'experimental' flag in the form does not match the 'experimental'
> flag in the plugins package metadata."
> And then:
> "This field is required"
> Sorry to bother, but something changed, because my metadata.txt file is
> the same that before.
> Someone knows what is changed ? There is a documentation ?
> Thank you
> Roberto
> Qgis-developer mailing list
