[Qgis-developer] Rotation status and PSC meeting
Mathieu Pellerin
nirvn.asia at gmail.com
Thu Jan 15 18:00:38 PST 2015
Sandro,
The last few weeks has been a nice leap forward when it comes to your
rotation feature, congratulation on that.
IMO, based on the improvements, it's worth considering _removing the
activation option altogether_ from the preference window. I can't see
any stability and usability issue that would warrant disabling it.
That said, in my view, a basic composer support (i.e. map item's
rotation feature) should be moved at the top of your priority list.
Right now, the benefits of your rotation work _cannot_ be exported
outside of the QGIS canvas, which IMO is a serious limitation. In most
of my QGIS workflows, the final cartographic products are exported
through the composer to obtain an high resolution file that can be
printed out (i.e. I can't just go save the canvas as an image :) ).
Not having map items make use of your rotation feature is a
significant restriction.
Cheers, and thanks again for the work,
Math
On Thu, Jan 15, 2015 at 9:59 PM, Sandro Santilli <strk at keybit.net> wrote:
> I've spent more time on rotation (only partially funded), fixing:
> - Label pre-rotation (#11814)
> - North Arrow Decoration (#11818)
> - Grid decoration (#11817)
> Leftover issues (open for funding):
> - Plugin layers (#11900) -- needs feedback
> - Overview map (#11862) -- minor, IMHO
> - Composer support (#11912) -- wish ?
> - Atlas doesn't consider map rotation when setting scale (#11954)
> Please report any other issue that might arise with rotation enabled
> and properly tag it with the "rotation" label.
> I'd like to partecipate to the PSC meeting tomorrow but it is only
> possible for me before 18:00 CET. I hadn't found the schedule here:
> http://hub.qgis.org/wiki/17/PSC_Meeting_16_January_2015
> At what time do you plan to meet ?
> --strk;
> () Free GIS & Flash consultant/developer
> /\ http://strk.keybit.net/services.html
> Qgis-developer mailing list
