[Qgis-developer] Data-defined buttons for "en masse" size and rotation
Anita Graser
anitagraser at gmx.at
Fri Jan 16 13:47:33 PST 2015
Dear Vincent,
Thank you for your thoughts and the detailed explanation! Maybe its
just me, but I'm having a hard time imagining everything described
without seeing some UI mockups. Would it be possible to show dialog
examples of what you are planning?
Best wishes,
Anita
On Fri, Jan 16, 2015 at 6:29 PM, Vincent Mora <vincent.mora at oslandia.com> wrote:
> Hi all,
> As an attempt to "Improve GUI consistency & UX for data-defined style"
> (#9881) I'm planing to add a data-defined button[1] to the "en masse" size
> and rotation changing fields [2].
> This could *replace* the scaling factor, scaling method and rotation
> available in the 'Advanced' menu.
> After that a graphical assistant (accessible from the data-defined button)
> will be developed to help the user define the scale-function (preview the
> various symbol sizes).
> I'd like to have your impression on that change, especially on the
> *replace*, and comment on the plan below.
> Thanks,
> V.
> [1] QgsDataDefinedButton: the button already in the Label properties for
> data-defined properties.
> [2] What I call the "en masse" size and rotation fields are the fields Size
> and Rotation displayed at the Marker level for simple symbol and the popup
> for size in the graduated, categorized and rule-based symbologies (I plan to
> add rotation there too).
> Data defined property buttons will be added to the "en masse" change fields
> for single symbol, graduated, categorized and rule-based symbologies.
> This is especially useful to be able to use scaling functions to define the
> size of the scaled symbols:
> - Flannery (recommanded): scale_exp( variable, minValue, maxValue, minSize,
> maxSize, 0.57 )
> - Area : scale_exp( variable, minValue, maxValue, minSize, maxSize, 0.5 )
> - Linear : scale_linear( variable, minValue, maxValue, minSize, maxSize )
> Using an expression at the "en masse" level will set expressions for all
> symbols composing the marker. The behavior will be the same as with size and
> rotation changing: the expression will be the one of the last symbol in the
> marker, others markers will be scaled/rotated relative to the last marker.
> For the size, if the scalling method is area, the scale factor will be put
> inside the sqrt(). If size/rotation are defined by expressions/fields, those
> definitions will be lost.
> Definition: "en masse" expression pattern:
> - Size with scale method Area
> - `sqrt( expression )` for the last symbol of the marker
> - `sqrt( symbolSize/lastSymbolOfTheMarkerSize * expression )` for other
> symbols
> - Size with scale method Linear
> - `expression` for the last symbol of the marker
> - `(symbolSize/lastSymbolOfTheMarkerSize) * expression` for other
> symbols
> - Rotation
> - `expression` for the last symbol of the marker,
> - `expression + (symbolRotation - lastSymbolOfTheMarkerRotation)` for
> other symbols
> Disabling "en masse" will disable all size/rotation expressions for markers
> composing the symbol if they match the "en masse" expressions pattern.
> Note that the data-defined expression at this "en masse" level will only be
> set (yellow highlight) if the size/scale expression of all the symbols
> composing the marker match the "en masse" expression pattern.
> To avoid functionality duplication the scale and rotation could be removed
> from the 'Advanced menu'. This will simplify the symbology classes. To
> ensure backward compatibilities of old project files, the following
> scaling/rotation expression can be defined using old scale/rotation
> parameters to ensure the same rendered map:
> - For size
> - newSymbolSizeExpression = sqrt( oldScaleExpression *
> oldSymbolSizeOrSizeExpression )
> or
> - newSymbolSizeExpression = oldScaleExpression *
> - For rotation:
> - newSymbolRotationExpression = oldRotationExpression +
> oldSymbolRotationOrRotationExpression
> As a result, if expressions are used for the symbol size/rotation in
> addition to scalling/rotation of the marker, the replaced expressions (with
> scale/rotation included) may not match the "en masse" expression pattern and
> the data defined button will not be highlighted. This seems to be a minor
> and rare inconvenience since it will happen for project with scaled/rotated
> markers composed of multiple symbols with different data-defined
> size/rotation.
> Qgis-developer mailing list
