[Qgis-developer] new "lock layer styles for map item" button in print composer
Martin Dobias
wonder.sk at gmail.com
Mon Jan 19 07:34:42 PST 2015
Hi Matteo
I hae just realized that it was possible to lock layer styles even if
layers are not locked (the checkbox above). I have just pushed a small fix
for that. Anyway, if you make sure that "lock layers for map item" is
checked before locking layer styles, it should work.
Cheers
Martin
On Mon, Jan 19, 2015 at 9:57 PM, Matteo Ghetta <matteo.ghetta at gmail.com>
wrote:
> Hi all,
> I made some test with the new Save styles function and I noticed that the
> possibility to lock the styles in the map composer doesn't work.
> Shouldn't the new "lock layer styles for map item" button "freeze" the
> style for the current map composition? If I change the style in QGIS the
> style is not locked in the composer.
> Am I missing something?
> Cheers
> Matteo
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150119/f3fe13a0/attachment-0001.html>
