[Qgis-developer] SPIT still functional?
Olivier Dalang
olivier.dalang at gmail.com
Tue Jan 20 16:38:45 PST 2015
Heh didn't know about this !! Great news, I'll try ASAP !
Actually I didn't see it because it wasn't displaying in my processing
toolbox, since I had an old processing plugin installed (v 2.2) that was
hiding the newer one which is now shipped with QGIS.
Shouldn't we remove the old processing plugin from the repo ? (or at least
set it's max version to the version where Processing was included in QGIS ?)
Thanks !!
Olivier
2015-01-20 21:27 GMT+00:00 Giovanni Manghi <giovanni.manghi at gmail.com>:
> > Hi,
> > As I said on the user list ( thread : "Import (not so) large data into a
> > remote postgis database" ), SPIT has the advantage of showing a progress
> > bar.
> > This is a good feature when uploading data through a slow connection (my
> > case these days).
> > But I think it would make sense to move this feature (the progress bar)
> to
> > the DB manager.
> > I tried to do it [1], and it kind of works sometimes, but there's some UI
> > refreshing issues, and I won't time to investigate much more these
> days...
> > Maybe we should also think about making the import more efficient and
> > robust. I'm currently working with a slow connection, and uploading a
> table
> > of around 4000 lines takes ages (around 2 hours).
> > I don't really understand what the bottleneck is, but the transfer rate
> is
> > way under the transfer rate I'd have if I uploaded a dump file and ran it
> > online.
> > All more efficient ways (pg_dump, ogr2ogr, pgdump,...) are not suited for
> > non power users...
> Hi,
> since we have this
> https://github.com/qgis/QGIS/pull/1674
> I really think that SPIT can be dismissed.
> This new tool is much faster than any other option available in QGIS,
> and it has a lot of options. And of course it can be run in batch
> mode.
> cheers
> -- G --
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150121/8bc5df62/attachment.html>
